Portable Speaker quasi stereo - diyAudio
Old 23rd August 2014, 09:07 PM   #1
Default Portable Speaker quasi stereo
I would like to try building a decent sounding portable speaker.
Using two 4 ohm tweeters and one 8 ohm woofer...
Can I use a crossover that is discrete L/R to the tweeters and bridges the L/R positive outputs to the single woofer?
Quasi- Stereo
Thanks,
DB
Old 24th August 2014, 12:12 PM   #2
Inductor's Avatar
You could cut low in the crossover and use a DVC for the woofer.
Old 25th August 2014, 01:10 AM   #3
If the tweeters only carry stereo signals, then probably there will be little to no audible stereo reproduction. Also an adequate distance between a pair of drivers given L/ R signals, perhaps at least 3 feet, is a factor in hearing stereo.
My suggestion would be to replace the pair of tweeters with a pair of 3" full-range drivers.
Are you integrating the amplifier with the portable speaker? If so, a crossover network at line level, including mixing L and R bass signals (to be reproduced by the woofer) IMO would be the best route to follow.
The terminals of the woofer connected across L/ R positive terminals of the stereo power amp results in a difference signal to the woofer.
Pete
Portable stereo battery help Shawry Everything Else 4 14th February 2013 07:10 PM
Extremely portable mini stereo - Help with parts voyage Class D 4 27th February 2011 03:33 AM
Quasi amp, now in stereo Tekko Solid State 1 17th January 2011 01:55 PM
Project: Building a portable outdoor-stereo Rallen Class D 6 10th June 2010 06:08 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
