Using Scan-Speak 15W8531K00 - diyAudio
Old 23rd August 2014, 07:16 PM   #1
JackM11 is offline JackM11  United States
Default Using Scan-Speak 15W8531K00
I would like to use the 8531K00 in small a PartsExpress 0.28 cu ft cabinet using a port.
Is the cabinet too small? I like to keep the cabinet small if possible.
I have a pair of Usher 9950-20 tweeters. Would this work well enough with the woofer?
I have the mentioned parts and ready to go.
Thanks in advance for any suggestions.
Old 23rd August 2014, 07:35 PM   #2
vinylkid58's Avatar
You'll get a bit more bass if you can go to 0.375 cu ft. Seems a shame not to get the most from these little woofers.
jeff
Old 24th August 2014, 12:08 PM   #3
Inductor's Avatar
Make it an extra space beyond the 8.6L = 0.30ft³ because this driver needs an extra long port or you will end with a to tight small speaker.
Old 24th August 2014, 01:07 PM   #4
Download one of the free speaker box modeling programs. With that tool you will be able to see the response of your very highly regarded driver in a variety of box sizes. They pick one that will suit your size needs and maximize bass extension.
"It's all about the music!"
Old 24th August 2014, 07:04 PM   #5
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Jack,
With 2" in diameter, the length of the port would be around 12"
and you would probably need to find a solution ( elbow) to fit one.
This was simulated using Woofer Box and Circuit designer.
Jeff Bagby's Software Page
With the right XO filter it would sound very good.
It is so good that you exist !
Old 24th August 2014, 09:19 PM   #6
Hampes is offline Hampes  Sweden
trolle used 0.43 cu ft
Old 24th August 2014, 10:02 PM   #7
Can't find the 8531K00 and suspect with real world driver
parameters your only sensible option is sealed that small.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 25th August 2014, 05:09 AM   #8
Thanks everyone for your suggestions.
It seems I need a bigger box, say a PartsExpress 0.38 cu ft(10.7L)box.
Hopefully with a bigger cabinet the port length is more reasonable. I guess a smaller 1.375 inch port is too small.
I am going to do some simulations. Thanks again.
Old 25th August 2014, 07:11 AM   #9
Lojzek's Avatar
According to Zaph, I quote:
"For vented boxes, most woofers 6.5" and under use a Parts Express 1.5" flared port.
My own experience finds people making their ports *way* larger in diameter than they
need to be, which relates to longer ports."
End of quote.
So he sais under Enclosures topic:
Zaph|Audio
Old 25th August 2014, 07:48 AM   #10
There is another way : passive radiator.
My vol. = 13.5 liters and an old Philips passive. I tuned , by imp. curve, the passive by adding weight.
Weight = self adhesive bitumen pads.
The idea was based on the "old" Sonus Faber extrema.
I use a kind of sine-cap x-over as wel.
Leon
FS: Scan-Speak Illuminator d3004/60200 Tweeters, Scan-Speak Discovery 10f Midrange bikinpunk Swap Meet 1 27th September 2010 03:13 PM
3-way Scan-Speak marvii Multi-Way 9 15th April 2007 04:14 PM
scan-speak 3-way dre73 Multi-Way 1 18th November 2005 01:05 AM
Scan-Speak Madmike2 Multi-Way 8 24th September 2005 07:25 PM
New vs. old Scan Speak? Mr Ekan Multi-Way 1 5th April 2004 09:50 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
