Using Scan-Speak 15W8531K00
@ Biagio ;
There is more info on my Facebook group : extreme diy loudspeakers.
More pics etc.
Just take a look & if you need more ; pm me.
If more people interested ; we start a new thread and not use this one !
Added the David & Goliath pic !! :):)
gr. Leon
: Eek: I think I heard the twin brother of Goliath, to the house of my friend Fernando, passionate DIYer, it looks so impressive, though probably the technical solutions adopted are different.
Great, great sounding system, I'd like to hear at this point the voice of David.:)
Hi Jack,
I suggest you do 1,5" by 6". F3=45; F6=38 and F10=33 Hz according
to sim in a 0,35 cu ft box. F6 and F10 are important for better bass
and these are 10 Hz lower than with 2" by 6". You will do fine.
Thanks.
I continued on with a PCD simulation using an 0.38 cu ft PartExpress box, baffle 8 inches x 14 inches. Woofer center 6 inches from the bottom, woofer center to tweeter center Y axis 5.5 inches, port 2 inches x 6 inches. Woofer to tweeter Z axis offset -0.5 inch.
Looks reasonable? I try to aim for a flat response to begin with, if I am using the software correctly.
