Hello, I'm needing to purchase a bunch of replacement speakers for a project, the old speaker is discontinued... and I'm not an audio or speaker person so I was looking for a little help, here's the spec's on the current speakers
It's the Tangent EVO EV4 Bookshelf Speaker
link: Tangent - EVO E4 bookshelf speaker
Specs:
System: 2 ways
Frequency range (+/- 3dB): 70 - 20000 Hz
Impedance: 4-8 Ω
Sensitivity: 85 dB
Max music power: 100 Watts
Recommended amplifier: 20-100 Watts
Terminal type: Single wiring
Terminal finish: Silver plated
Input: Speaker level
Internal wiring: 99,99% OFC
Enclosure: Closed box
Magnetic shield
Dimensions
With grill and terminal (W x H x D):
4.9 x 7.5 x 6.3" / 125 x 190 x 160 mm
With base and spikes (W x H x D):
They were running this speaker with this amplifier:
Kenwood 350W KAC-5230
link: Kenwood - KAC-5203
This project is to be mounted on a bicycle, we're building a bracket to hold the speakers, and the amplifier, along with a 12V motorcycle battery to power the amplifier.
I don't know much about this stuff, but seems like the 350W amplifier was probably not a good match the with 100W speakers. I've gone on Amazon and found a bunch of speakers... I searched for outdoor speakers (cause it's on a bike),
like these:
Speaker 1
Speaker 2
Speaker 3
Speaker 4
Do these seem like good replacements?
Do these speakers require external power or is all that handled in the amplifier?
Does anyone know of a better amplifier that can run off 12V for this project?
Any input would be greatly appreciated, much thanks!
Specs:
System: 2 ways
Impedance: 4-8 Ω
Sensitivity: 85 dB
Magnetic shield
Dimensions
like these:
Speaker 1
Speaker 2
Speaker 3
Speaker 4
Thanks, so why does it say its 350W? Is that just for marketing?
Their specs is :
RMS Watts Per Channel @ 4 Ohms, 1% THD+N 55 W x 2
As professional electrician I would say that your battery source is not strong enough for this project.
This amplifier needs max 24Ampere x 14.4V (cars voltage) you get your 350W of power.
And your speakers at 100W music power ... they are actually close to 50W RMS at 8 Ohm and close to 70W at four ohm (true watts), therefore this setup it can cooperate in a car, in which there is a generator to feed it.
Thanks. Does anyone know if these speakers I found on Amazon are close to the original EV4? I'm just looking for replacement speakers, and then I'll probably tackle getting a better amplifier for this project.
thanks!
None of the speakers that you found on Amazon will be the quality of the Tangent. (Sound Wise) But, I believe any of your choices would work for your situation. It just depends on the money that you want to spend..
Here's some speakers that are close to the Tangent..
Pure Acoustics Dreambox Compact Hi-Fi Speaker Pair Bordeaux
May I suggest an amplifier that I use daily. Inexpensive and very reliable! I run a pair of Jamo bookshelf speakers with it and there is plenty of volume..
http://www.amazon.com/Lepai-LP-808-...?ie=UTF8&qid=1408329048&sr=8-7&keywords=lepai
I can operate this amp on a 7aH. 12 volt sealed lead acid battery for several hours at more than normal levels. Has both RCA and 3.5mm inputs. Easy speaker connections and small in size.. (Treble, Base, and Volume controls) They send a power cord with the amp but you would need to crimp some female 1/4" tab connectors on the wires and be very certain that you have the polarity correct! (Center Positive)
A sealed lead acid battery would be safer than a flooded cell in your situation. No worries of spilling acid..
Amazon.com: Rechargeable 12V 7AH Sealed Battery: Electronics
Hope this helps..
When you mentioned that none of the amazon speakers I pointed out were of the same quality as the Tangent I'm trying to replace, is that just from experience and knowing these brands or could you tell from the specs? And the Pure Acoustic, have you heard these or do you know they are comparable to the Tangents from the specs?
thanks!
thanks!
IMO..
Most often in the speaker world, money does "Talk". More money, better sound. Not always true but most often it is..
I never listened to the Tangents or the Pure Acoustics but by the price range, I figure that they both sound sweet! Specs are close. The Pure Acoustics have a smaller woofer than the Tangents but the wattage ratings are within 20 watts of each other.
- looking for a replacement speaker
