Up/Down Firing Omni
Up/Down Firing Omni
Old 16th August 2014, 07:46 PM   #1
siruis815 is offline siruis815  United States
Default Up/Down Firing Omni
Hi guys.
So we got a glance into the new house the other day and the living room is much smaller than the old one. This of course means that my rather large open baffles will no longer be an option. Even my large-ish full range MLTL may not integrate well into the room.
To try and conserve space I was pondering about using 2 ~2-3" midrange drivers in a bi-polar/omni configuration (speakers firing towards the ceiling and towards the floor) from a suspended (possibly spherical) enclosure. Maybe add a front or front/rear pair of tweeters to solve the beaming issue. Or of course go straight front/rear bi-polar firing full ranges (possibly Mark Audio's or Fountek's).
The small full ranges will be supplemented with some kind of bass driver...that'll be up for design later.
Any thoughts on this?
Old 17th August 2014, 01:33 AM   #2
OllBoll is offline OllBoll  Sweden
You just described the LxMini =)
http://www.diyaudio.com/forums/multi...-speakers.html
Old 17th August 2014, 01:13 PM   #3
graaf is offline graaf  Poland
graaf's Avatar
in a small room try on- or next-to-wall Beveridge placement
"high phooey and hystereo" - Yascha Heifetz
Old 17th August 2014, 01:20 PM   #4
graaf's Avatar
Originally Posted by OllBoll View Post
? not exactly
Old 17th August 2014, 01:23 PM   #5
Originally Posted by graaf View Post
? not exactly
Not exactly no, but similar enough that the Pluto / LXmini is worth looking closely at for research purposes.
Old 17th August 2014, 01:48 PM   #6
The LXmini does look interesting - I'm not sure why I didn't take a look at it when it first came out.
Any one have thoughts about omni/vertical bipole?
Old 17th August 2014, 01:50 PM   #7
Omni should always work, but with downwards firing not work as well because carpets will probably attenuate high frequency content. Upwards firing works though and sounds nice when done well, I have a pop box clone myself ( though it has been retired to make space for large dipoles that sounds even more nice )
Old 17th August 2014, 01:52 PM   #8
@graff - I had to look up the beveridge placement via google... it took me to the up firing floor coupled speaker thread. I've looked through there a few times before and I'll give it another good reading, although I'm not sold on having the speakers on the floor with two little kids running around. We'll see. Thanks for the suggestion and again, I'll read through the thread.
Old 17th August 2014, 01:55 PM   #9
You could always build a cage around them and cover it with acoustically transparent fabric. If I remade my omnis that is the number 1 thing I would do, the upwards mounted woofer collects lots of dust and I was always terrified I would drop something on them and break the speaker =)
It will look nicer too which is always a bonus.
Old 17th August 2014, 01:57 PM   #10
@OllBoll - definitely looking for something that takes a bit less floor space. My previous open baffles had an OB mid and monopole CD on one stand with 21" woofers on the ceiling. The new house doesn't have the real estate for such a thing.
With the high frequency content being attenuated by carpet and beaming at the ceiling, do you feel some "helper" tweeters will work?
Up/Down Firing OmniHide this!Advertise here!
OMNI Gallery gainphile Multi-Way 94 11th December 2015 11:37 PM
Omni Ribbon båndsei Planars & Exotics 35 4th October 2012 11:25 AM
Front firing vs down firing sub? alex_g Subwoofers 32 22nd June 2010 01:34 PM
Down firing vs side firing? Tee-Bruce Subwoofers 36 26th August 2009 07:32 AM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 03:13 PM
Copyright ©1999-2017 diyAudio
