Old 14th January 2004, 03:53 PM   #1
darkm4n is offline darkm4n  Romania
darkm4n's Avatar
Send a message via ICQ to darkm4n Send a message via MSN to darkm4n Send a message via Yahoo to darkm4n
Default URGENT : Mitre Angle for scoop speaker
Hi ,
Someone here have the mitre angle's for the this speaker ?
I use 18 mm plywood , someone know what dimension's have the board's inside the bin ? the angle one ?
I'am not so good at math .. so ... you understand ..
Bye ! Thanks !!!!!!
Old 14th January 2004, 04:55 PM   #2
mikee12345's Avatar
draw it in Qcad 1.4 and u can find out the angle of any of them.
I dont think i have enough info to draw it accurately.
Qcad link
Cheers!
Old 14th January 2004, 05:16 PM   #3
darkm4n's Avatar
Nope .. i can work in that .. i don't understand it ...
You don't know that angles ? and that mesurement's ?
Please help ..
Old 14th January 2004, 05:26 PM   #4
I may have misunderstood the question, but it seems like you can derive the cuts from the angles they provided (I highlighted them in yellow).
I wrote the final angles assuming a straight right-angle cut as "90" although depending on the tool you use straight up and down might be 90 or 0, so adjust accordingly.
Perhaps somebody would be kind enough to check my work, but I think it's correct.
Old 14th January 2004, 05:29 PM   #5
darkm4n's Avatar
Aha , THANKS !!!!!!!!
but i don't know the dimension's of that board's .. the angle one's .. there is nothing writed on them ..
Old 14th January 2004, 05:33 PM   #6
Oops, I'm sorry - I did misunderstand, and did the easy part that you probably already knew. I'll see if I can invoke the ghost of my high school trig well enough to figure the lengths...
Old 14th January 2004, 05:37 PM   #7
darkm4n's Avatar
Please try ...while i try with the cad software ..
THANKS
Old 14th January 2004, 05:52 PM   #8
OK:
The first one should be 1/cos(30) * 270
cos(30) = 0.866, 1/0.866 = 1.155
So the length should be 1.155 * 270 = 311.85
The third (longest) should be 1/cos(15) * (656-152)
cos(15) = 0.966, 1/0.966 = 1.035
Length = 1.035 * (656-152) = 1.035 * 504 = 521.64
I don't really know how to approach the shortest piece, since there are no right angles. I know it's possible to calculate, but I'm not confident enough in my skill in this area to give it a go. Sorry.
And again, I wouldn't go cutting a bunch of MDF based on these numbers unless you can get similar results in software, or somebody comes along and agrees I've done it right.
Old 14th January 2004, 06:00 PM   #9
darkm4n's Avatar
I think i found the solution .. thanks for you time !!
My result's were :
The first one ( the front one ) : 365 mm
The second one ( the longest , it face the scoop ) : 515 mm
And the small one , the bridge: 140 mm
I got a milimetric paper and draw a 1:5 scale model ... they i mesure those number's..
The value are close , i think the best is to cut them bigger and adjust them with my saw .. ( circular saw )
Old 14th January 2004, 06:04 PM   #10
Cheers, and good luck with your project!
Cabinet making: mitre-saw or Festool MFT? magentawhale Multi-Way 0 18th December 2007 07:37 PM
mid scoop switch for distortion pedal fingerwizards7 Instruments and Amps 0 27th January 2007 10:21 PM
Help me with SCOOP bracing . darkm4n Multi-Way 2 20th January 2004 09:45 PM
Scoop comparation darkm4n Multi-Way 2 14th January 2004 07:05 PM
how to build a bass bend/scoop cab Javalon22 Subwoofers 1 5th January 2004 04:28 PM
Page generated in 0.12801 seconds (73.86% PHP - 26.14% MySQL) with 11 queries
