Bi-Wiring / Bi-Amping
Hi!
Don't know if i'm thinking about this quite right.
An example i had with my friend. (See image for explanation)
If i have an DSP, outputing 'Woofer Channel' on A and 'Tweeter Channel' on B.
Putting A to Amp Channel 1 and
Putting B to Amp Channel 2.
And if i then Bi-Wire from Amp Output 1 to the Woofers and from Amp Output 2 to the Tweeters in Bi-Wire.
Would it work, and could i then control the gain on the Tweeter/Woofer independantly?
Don't know if i'm out in the blue with this one or not, please give me hand :D
Would work if the amp can handle 2 parallelled speakers regarding impedance but you will not get true stereo with this setup. The balancecontrol will more be a kind of a mixed tonecontrol :D
Biamping would require 1 stereoamp per speaker. One channel to the tweeter and the other to the bass.
