Guys,
I'm really stacked...Please read this thread http://diyaudio.com/forums/showthrea...threadid=25862 and give me any clue about what is happening. Nobody faced this kind of problem? |
#2 |
I think a measurement of the impedance down below 200 Hz might be an appropriate step. It will let you really see what's going on with the box tuning. If you could post that, along with the raw driver's measured impedance curve, that might be useful.
I don't usually make language notes, but "I'm really stacked" has an unfortunate implication in English (at least in American English). Well, fortunate if you're a girl, unfortunate if you're not.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 |
So,
If I understand right, you tell me to measure the impedance driver mounted in the enclosure? I have the impedance driver measured in free air, so I will post both of them today. Sorry about my language, I'm doing my best. |
#4 |
You do great in English- it's just that you've run into slang and idiom that I'm sure they don't teach in school!
Yes, you should absolutely look at impedance in the box. That will definitively tell you if your tuning is correct or not.
#5 |
Ok,
I will do this mesurement in a few hours and I will post it. But I'm sure that the impdance curve will not look like the one in MathCAD sheets...
#7 |
Somebody wrote in my last thread that I should check the Cone excursion...but I didn't really understood what he want to say with this. What do you think?
#8 |
Well, first things first. Let's see if you've hit the target at the small-signal level.
What sort of volume (sound level) were you using for the frequency response measurements?
#9 |
I'm using Speaker Workshop for mesurements.
So I use my sound card for nearfield mesurements. |
#10 |
One thing to be careful of is that you're actually measuring small-signal parameters. Keep the volume down.
| looking for FR graph for w3-871 | kifeinthesink | Multi-Way | 6 | 7th June 2008 07:15 AM |
| what is an FFT graph? | keantoken | Everything Else | 23 | 10th September 2006 12:13 AM |
| Graph shapes | Danielb | Multi-Way | 9 | 3rd November 2004 12:26 AM |
| What graph to look at? | pjacobi | Solid State | 3 | 18th February 2004 01:56 AM |
| help interpreting graph | getafix | Multi-Way | 6 | 12th October 2003 12:52 AM |
| Page generated in 0.09280 seconds (83.48% PHP - 16.52% MySQL) with 11 queries |
