#11 |
I am looking forward to Zaph's review of the tangband. http://www.zaphaudio.com/blog.html
The build quality does look impressive. If it tests well, it could make a good alternative to the seas 7" woofer (ever increasing in cost) -David |
#12 |
Hello squidbait,
[URL=http://www.audioheuristics.org/projects_gallery/RS225_RS28A_updates/dayton_reference_rs225.htm] Above is a link for a sealed design using a 8" driver. Just finished these up this last weekend, a very nice design with very nice bass. |
#13 | ||
http://www.carstereo.com/help/Articles.cfm?id=30 A box Qts of .707 is usually regarded as best. (hopefully LDC covers why) Assuming you want your bass to as deep as possible (F3), you will probably come to the conclusion that a driver Qts of .4 gives you the best combination of reasonable box size and deepest bass. JJ |
#14 |
JJ
Thanks for the link. I have Marchand Bassis which adjust Q of sealed box, so I gues I can use a little high Qtc to get better bass. I got this Bassis for about 3 years ago, but I haven't had chance to really make use of it yet. Doug |
| Best 10 inch sub drivers for sealed enclosure | brox | Subwoofers | 17 | 14th March 2007 08:40 AM |
| Best Drivers for 40 - 170 Hz Sealed Box ? | Oz_Audio | Multi-Way | 11 | 1st February 2007 07:36 PM |
| Twin volt drivers in sealed box enclosures | jez | Multi-Way | 5 | 21st March 2005 02:48 PM |
| Calculating EBP for sealed enclosure drivers... | sberube | Multi-Way | 2 | 4th June 2004 09:14 AM |
| MTM’s or TMM’s: using sealed upper and TL (or similar) lower drivers? | Andy G | Multi-Way | 3 | 18th November 2002 05:46 AM |
| Page generated in 0.08883 seconds (73.51% PHP - 26.49% MySQL) with 10 queries |
