ZRT crossover capacitor damage?
Old 31st July 2014, 07:35 AM   #1
Thedaus is offline Thedaus  Australia
Default ZRT crossover capacitor damage?
A few years ago I started building a pair of Zaph ZRTs, including the crossovers. Things happened that have stopped me from thinking about finishing them till recently.
When taking a look at the crossovers that I had mostly finished building some years ago I noticed that the Jantzen audio CrossCaps that I have in the crossover have a dark orange/brown slightly sticky substance on their ends and that the ends of the caps faintly show that they are not completely flat, instead they look like they have slightly higher bubble shaped areas with lower areas in between (that the strange substance likes to fill).
At first I thought it was some flux from my bad soldering job, but it seems to also have happened on caps that I have not got around to soldering yet (thus also ruling out heat damage)!
Has anyone else had this happened to their caps and does it mean they are somehow damaged?
Old 31st July 2014, 04:22 PM   #2
Bare is offline Bare  Canada
Clearly something Substandard in there.
I have unused pedestrian Solens, date stamped from early 90s, that look and test No different than when bought.
Loose those... and don't buy more :-)
Old 31st July 2014, 05:42 PM   #3
fatmarley is offline fatmarley  England
Aren't cross caps polypropylene? Got a photo?
Old 31st July 2014, 10:07 PM   #4
Sorry about the really out of focus shots, but it should be visible.
Note that the first cap is fully soldered up and the second is soldered on the other side, I could not get a good shot of the unsoldered cap that is also showing the same signs though.
Edit:
The unsoldered one Click the image to open in full size. Click the image to open in full size.
Old 31st July 2014, 10:39 PM   #5
If these caps are bad it puts me in a tough spot, it would cost $200 + shipping to the other side of the planet to get the predone madisound crossovers ($150 + shipping for just the caps alone).
The place I got the parts I have now are from a local place that still only sells Jantzen (and other semi local places sell caps for a lot more)
Old 31st July 2014, 10:49 PM   #6
Jsixis is offline Jsixis  United States
put a meter on them. What you are seeing could just be environmental dirt
I know nothing, so learning is really awesome.
Old 31st July 2014, 10:58 PM   #7
I don't have a meter (so that is an other $50) and if it was dirt would it not be on everything, not just the ends of the caps?
Old 31st July 2014, 11:17 PM   #8
You can use a ohm meter, you'll see a brief moment continuity then it will drop to infinity
could have just been a sticky spots during production that over time change colors or picked something up. those are suppose to last a decade or two and with today's production failures are extremely rare.
Cat may have sneezed on them, spiders may have mated, I've seen smoke do that after some condensation, who knows, did you try wiping it off, damp rag?
Old 31st July 2014, 11:29 PM   #9
Probably spilled a can of coke on them or something. I'd be very surprised if it was coming from inside the cap.
Old 1st August 2014, 12:06 AM   #10
I did try to wipe them off, did not really do anything.
I could scratch a bit off with a fair amount of effort though.
Ha, I think I would remember that.
ZRT crossover capacitor damage?Hide this!Advertise here!
Crossover capacitor voltage andykap Multi-Way 10 17th November 2017 10:56 PM
Capacitor as a crossover? adri123 Full Range 6 31st March 2014 11:42 PM
crossover damage likely? Daem Multi-Way 7 2nd July 2013 11:02 PM
Crossover capacitor choice Jonasa Multi-Way 47 5th November 2009 11:15 PM
speaker or crossover damage evlah Multi-Way 9 19th March 2008 03:49 PM
