New speaker build - diyAudio
Old 30th July 2014, 10:12 PM   #1
djn is offline djn  United States
djn's Avatar
Default New speaker build
I've been very busy turning stuff on my lathe and have gotten away from audio for a while. Just in the last weeks, I've gotten the itch to build a pair of speakers...which I don't need. I just need to do some experimenting.
I just picked up these six drivers and two crossovers for 25 bucks. They came from a Visio Sound Bar but I am thinking about doing towers with subs in the bottom.
Does anyone know these drivers???
Here are the components I was thinking about using for the sub bottom.
http://www.parts-express.com/project...the-triska-sub
C&C are welcome.
My "Art" website http://home.comcast.net/~djnagle/site/
Old 30th July 2014, 10:34 PM   #2
picowallspeaker's Avatar
I've made something similar to the Triska sub. I didn't put any "internal amplifier".
I just needed to put in use a pair of (lo-power) Peerlees subs, one of them had a detached VC former from the cone so I made it become a passive.
Somebody told me it was better to put the passive on the opposite face of the "cube"...
Only afterwards...!!!
Old 31st July 2014, 03:34 PM   #3
djn's Avatar
I already have the two plate amps that go to the Triska so I just need the drivers and PRs. in the plans it talks about using only 1 PR but the pix show him using 2 per box. What gives?
Old 31st July 2014, 03:53 PM   #4
jReave is offline jReave  Canada
Two PR's per sub.
Old 31st July 2014, 04:11 PM   #5
Whatever; I wouldn't put any electronic inside a box where there's a speaker.
Especially a sub !!!
Damping factor with the added Re of some feet of wire wouldn't suffer much
Old 31st July 2014, 04:11 PM   #6
djn's Avatar
Thanks J. That is what I figured and was going to order, I just thought it interesting that I've seen them with only one PR.
Old 31st July 2014, 04:13 PM   #7
djn's Avatar
Damping factor with the added Re of some feets of wire wouldn't suffer much
I've gone back and forth about that P. I built my main subs years ago and have the Bosh 300 mounted in each box (I built two of them) and they are still rocking. Go figure.
Old 31st July 2014, 04:16 PM   #8
It's philosopical; I stay better with myself
About figuring it out: what about the continuous and tremendous vibrations
that the electronics ( which is just a bunch of components attached to a PCB )
"feel"...or they don't ?
Old 31st July 2014, 09:26 PM   #9
djn's Avatar
Here is the dilemma; These will go to my nephew for his dorm room next year. So they need to be neat and tidy, but they are going to a dorm room so they will most likely be played hard and loud, so the amps should be outside the box.
Old 1st August 2014, 04:15 AM   #10
djn's Avatar
I was rooting around my stash and found two 12" subwoofers. I don't have any data on them except what I could get using WT3. So I have the subwoofers, the plate amps, four mids and two tweeter plus the crossover. All I need now is a sheet of MDF and I am set.
Here is a screen shot of the subwoofers.
new speaker build slr 5000 Multi-Way 10 4th June 2013 09:41 AM
First Speaker Build, Help! J Smith Construction Tips 12 6th May 2013 11:40 PM
need help with a speaker build...Please! gmanbluesman Multi-Way 6 7th January 2012 02:46 AM
First 2 way speaker build. pj1008 Multi-Way 3 1st October 2011 12:49 PM
1st speaker build - BIB with ____ FR speaker? keillor Full Range 28 5th October 2010 07:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
