Substitute for SB29RDC? - diyAudio
Old 29th July 2014, 06:40 AM   #1
juanito is offline juanito  Europe
juanito's Avatar
Default Substitute for SB29RDC?
Hi, I'm looking to replace the SB29RDC tweeters from the Recession Buster Reference kit: is there a substitute without changing the crossover?
Thanks in advance.
Old 29th July 2014, 08:42 AM   #2
I would be very surprised, crossover is not only defining from which frequency the tweeter is responding but usually also improving linearity, as no speaker is ever fully linear. if the previous one had a bump around 6000Hz and the new one has one around 9000, they wont match. If you decide to go for a different tweeter, I would always exchange both sides.
what is your reason to exchange them? If they are broken, my personal preference would be trying to find the original
without too much shipping cost, you could get them here: https://www.intertechnik.com/Shop/17...p/&transport=#
if they are too harsh, think about removing some of the sonofil, increasing the volume of mid and low will decrease tweeter presence
Old 29th July 2014, 09:07 AM   #3
juanito's Avatar
Thanks, yes I would change both, is just that I woul like to try diferent tweeters and I wonder i there are any replacement that match with out changing mich the crossover.
Old 30th July 2014, 08:23 AM   #4
I see - what is it that you're missing in the SBs? Maybe a little change in the crossovers would already do the trick?
Old 30th July 2014, 08:26 AM   #5
I recently listened to these: Satorique, the High End Formula of small speakers - July 2014 - Loudspeakermagazine 2014 | Loudspeakerbuilding
was quite impressed by the performance - and they also have a dome tweeter by SB. The TW29R is a bit more on the high end side though...
Have a look at the link I posted, maybe compare the measurements of the tweeters - if the curves are more or less similar and the data fits that might be worth a try
As said, I guess it will be quite hard to exchange the tweeter without changing the crossover. I always try to listen to a speaker before building it - not always easy, but sometimes driving a few hundred km makes a difference.
Old 30th July 2014, 05:14 PM   #6
dragonweed's Avatar
Actually there is not much difference in subjective sound quality of the Satori tweeter, and the RDC 29 (at least not as much as in price). For 50 Euros it is not an easy task to better the SB-s. Maybe some of the Illuminator, or Accuton ceramic domes perform better, but at 4-6X price tags. Also the SB-s are workable from 1.5 kHz with 2nd order XO (fs 600 Hz), so it will not be easy to find a reasonably priced replacement to them. I found them easy to work with, natural sounding, fast, with excellent top end resolution, so not sure why you want to replace them.......
Old 30th July 2014, 05:25 PM   #7
dragonweed's Avatar
In fact I can assure you, that if this tweeter doesn't sound "right", then something is definitely screwed up in your crossover. Be aware of the fact, that since it has no ferrofluid damping, if your XO frequency is low (below 2k) then without proper resonance filtering the Fs "peak" will cause a rather nasty coloration....
SB29RDC-C004 strangeness tvrgeek Multi-Way 19 13th March 2013 12:45 AM
My own back for the SB29RDC tweeter tvrgeek Multi-Way 0 13th January 2013 09:28 AM
SB29RDC 2-way? GOWA Multi-Way 6 13th October 2012 11:48 PM
FS: SB Acoustics SB29RDC-C000-4 tweeters cs Swap Meet 2 14th June 2011 09:22 AM
Help getting 15W/8530K00 and SB29RDC togeter nelsonvandal Multi-Way 1 6th April 2010 08:34 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
