2.1 Plate amp and Comosite - diyAudio
Old 28th July 2014, 08:34 PM   #1
Default 2.1 Plate amp and Comosite
Would it be possible to run a 2.1 speaker setup using a 2.1 plate amp fed from the composite connection straight from the TV?
Old 29th July 2014, 05:29 AM   #2
picowallspeaker's Avatar
Hi, the term "composite" is used in the video section, I guess, such as RGB...
When the audio signal goes thru 2 wires is called "stereo" or "two-channels".
The signal that goes to the subwoofer amplifier is derived directly from the two channels by summing them ( so>>mono) and a steep low-pass filter set below 100 Hz.
Old 29th July 2014, 12:14 PM   #3
I apologize if I used he wrong term. I am referring to the Red and White stereo connection for audio only. I am hoping for improved audio without the need of an AV receiver.
Sent from my iPhone using Tapatalk
Old 29th July 2014, 12:57 PM   #4
Speakerholic
Cal Weldon's Avatar
As long as the output is variable, you wil be able to control the volume with the TV remote. If not, you have to use the gain or volume control on the plate amp which can be a pain.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 29th July 2014, 01:12 PM   #5
Difficult, I fear. As long as they ( Tvs) have available thru RCA's or via SCART only the line output but not the pre output.
Sort of pre-out is available at the headphones jack, with a little more distortion because of the amplifier stage ( being it simply derived with resistors from power amplifier's output or with dedicated low power amp ).
Old 29th July 2014, 01:52 PM   #6
Speakerholic
Cal Weldon's Avatar
It depends on the TV. Check to see if the RCA line level outs are variable.
Simplified pentode Loftin-White with plate-plate feedback homeskillet Tubes / Valves 17 3rd August 2013 04:58 AM
5k plate to plate, el34 triode strapped, 400v b+ blue andry Tubes / Valves 12 27th February 2012 01:03 AM
EL84 PP using 5K plate to plate primate OPT jmillerdoc Tubes / Valves 5 9th March 2010 09:14 PM
DIY Plate Amp --> Need the Plate!!! gmikol Parts 4 17th February 2006 08:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
