DSP midrange directivity control aka kinda cardioid - diyAudio
Old 27th July 2014, 05:10 AM   #1
Default DSP midrange directivity control aka kinda cardioid
My goal here is to use my current midwoofers (TD15m) from 80-1000ish and have controlled directivity from 300hz up. In my room I'd like to have a 60 beamwidth and I'd make elliptical os waveguides to match, but I won't settle for anything more than 90.
There's really three ways that I see to do this: dipole, cardioid(or variations thereof), or some big horns. I don't like dipole because that's a 120 pattern and I don't like the rear energy bouncing off the front wall....been there and done that. Horns will be another project. So that leaves cardioid. I've seen several passive resistance diy designs online, but nothing that really looks good over 400hz.
Being the pc dsp dork that I am I thought I would try an active cardioid using smaller drivers on the rear or sides of the cab. Linkwitz says a cardioid can be made with 2 monopoles back to back, with the rear driver out of phase and delayed the time it takes to reach the front baffle plane. I'm using some junk 2cu ft sealed cabs, old (early 80's...older than me!) 15" Eminence woofers and 8" Vifa hifi drivers. The first implementation was a single 8" on the back. I tried different delay settings, levels, as well as hi and low pass on the 8" but could only get good results up to 400hz. Above that things get goofy. Sorry didn't save the data.
I wasn't surprised considering the cab is 15" deep which is more than a wl at 1khz where I want to xo.....so I put an 8" on each side of the cab about 3.5" from the front baffle plane. I ended up delaying the main 15" by .25ms (which I thought was odd). The 8's are out of phase, -9dB in my dsp and have a first order low pass at 700hz. Here's 0-90:
And a polar plot:
Sonogram? Why not:
Not bad! Right around 90 or less from 300 up. As you can see it's really only cardioid at 1khz with a good bit of rearward energy as you go down in freq. I'd like to see some better rear attenuation, and that 90 measurement is funny. These cabs already had a 12"x12" hole in the back that I covered with mdf, so I opened it up and stuffed them with bonded logic:
Here you can see that it didn't really affect the forward response, but attenuated the rear a good bit and tends toward a hyper-cardioid. Nice.
I did a lot of playing around with this. I could get a 60 beamwidth by shaping the side drivers with hi and low shelving filters, but it would create some serious lobing at 90 and beyond. Ideally I would have a driver on the back as well. That would need a channel of it's own for a different delay and that's getting too complex. We're talking 5 channels at that point for a 2.5 way speaker
I've got enough data at this point to feel comfortable moving forward with this. Any ideas on suitable 8" drivers for the directivity control? They're down quite a ways in level, and since they aren't really contributing to the direct sound they don't need to be anything special. I'm thinking the Dayton PA's. Also, any thoughts on the closed vs. open back? I'd like more attenuation to the rear but the open back does have more lf roll-off.
Measurements unfortunately were done in my garage, ground plane with a 5ms gate. I wanted to do them outside but it kept sprinkling off and on all afternoon, though I think it's good enough to see the general trend. Hopefully I can get out tomorrow.
Old 27th July 2014, 04:28 PM   #2
puppet is offline puppet  United States
A different approach that might work ...
A dipole woofer in front of a sealed box woofer. They would be wired in phase ... no delay. I know for a fact that the side would have a substantial null so you'd maintain the directivity you seek. Spacing would probably serve to shape the directivity somewhat @ lower frequencies. If you then control the sensitivity of the sealed woofer so as not to overwhelm the dipole in SPL, the sealed woofer output should be completely canceled .. at all frequencies .. leaving just the forward radiation of the dipole.
Old 27th July 2014, 05:00 PM   #3
ra7 is offline ra7  United States
Do you have room corners to work with?
Old 27th July 2014, 05:08 PM   #4
puppet - that's interesting! I've seen something like that before but honestly I hadn't even considered it. What kind of distance does there need to be between the sealed and dipole drivers? My only concern is the rear dipole output reflecting off the sealed cab.........though I suppose if there's cancellation then it's a non issue. I'm gonna try it.
ra7 - no corners. I do on the right but the left side has a 6' wide opening to my dining room starting 1' off the front wall. A bummer setup for my stereo but it's the best I can do in this house. Otherwise I'd be considering a corner horn setup.
Old 27th July 2014, 05:44 PM   #5
I'm doing this right now but .. dipole front and back .. open space between.
adason (here) had done something similar but used a box having the drivers on opposite sides.
Celestion also did this with their system 6000 with an open space between .. again all dipole.
One thing that I think people miss with this type of arrangement, particularly with the open area between, is that the combined drivers work like they are in a "U" frame. Two drivers boost the SPL, the separation creates the faux "U" frame depth, all without the associated resonances of a "frame".
A couple things to consider .. the acoustic center moves back to the center of the space between the drivers. How much space you'd have to experiment with but as I said before, the null is pretty substantial. What effect this will have (being a sealed box at the rear) on directivity I don't know for sure. Optimal spacing will be trial and error. I do think that you'll need to attenuate the rear "sealed" driver though. How much is experimentation as well.
GL .. let us know how/if this works.
Old 27th July 2014, 06:15 PM   #6
Cool. I'm not sure if it's what you had in mind, but I'm wondering about twin dipoles where the drivers are facing each other, and the sides are bent back 45 degrees, so that you basically get 4 x 90deg quadrants. However, these 'U' frames could then be sort-of boxed with lossy aperiodic panels or grills.
Thinking about it some more, that particular configuration will have a strong back-wave, but maybe there are other possibilities with lossy panels?
Old 9th August 2014, 02:37 AM   #7
I'm still plugging away at this. I've been getting some really nice (too nice) results with different setups that in theory shouldn't work......the garage ground plane measurements aren't cutting it. So, I took this stuff outside. Measurements done at about 12' from the baffle with a 60ms gate to get a rid of a reflection I think from my garage. The 220hz null is not in the driver but a reflection.
I measured the monopole (about 1.5cu ft sealed with a Eminence Delta 15" LFA) out to 180 to get a baseline. Very little eq, I think the highs roll off because I didn't have the cab angled towards the mic correctly:
Next is an acoustic resistance box (same box) that has 2 large slots cut on each side of the cab. Total area of the slots is about 150% of the driver sd. The baffle on these is 19" wide. The first slot is about 2" back from the baffle and the cab and slots are stuffed with Bonded Logic:
Fr tracks quite well over most of the range with around 100 beamwidth and good rear attenuation. I'm liking this but ideally I'd like a bit narrower directivity. You can see the pattern widen around 1khz (where I would probably xo) then start beaming soon after due to the driver size. I think the narrowing at 1khz is due to the slot spacing and the baffle width.
Next is the same cab, but instead of slots on the side I have an 8" woofer on each side with about 3.5" from the woofer frame to the baffle. Each 8" woofer has it's own enclosure within the main cab. The 15 and the 8s were eq'd relatively flat, and the 8s are -8dB, delayed .2ms, and low passed 1st order at 700hz:
The fr tracks pretty well here too, with maybe a bit less than 100 beamwidth. I'm sure I can narrow the pattern with delay, level, and fr changes to the side drivers. Monopole response below 250hz which I don't like. I don't think that directivity is important below 300hz or so, but an attenuated rear response might help with the front wall notch in the mid-bass.
Last, here's the cab with the side drivers again, only I have about a 15" square opening on the back side of the box as well. Still stuffed with BL and I was hoping to get some rear output cancellation:
The response out to 90 is mostly unchanged but you can see significant rear attenuation.
Old 9th August 2014, 02:47 AM   #8
puppet - I tried a couple different iterations of the closed box behind the dipole (in my garage, I need to try it outside) and got some pretty goofy results in the 800-1khz range. Goofy being high q peaks and dips beyond 5 or so off axis. Like I said I need to get outside to try that one again.
I also tried a dipole with a sealed woofer above and behind the dipole, thinking that I could get a smoother response but it was still pretty rough.
At this point, despite the title of thread, I'm leaning towards the acoustic resistance box with the slots in the side. I think it's pretty impressive to have a 15 with constant directivity over that kind of bandwidth that's not a dipole. It's a bit wider pattern than I would like but then I don't have to buy more drivers/amps. I'm going to build a test box for my TD15s with a 2" or so roundver and I'll get the side slots up as close to the baffle plane as I can.
Old 9th August 2014, 11:35 AM   #9
I would believe that the closer the slots are to the baffle, the narrower pattern. They can even start in the baffle in extreme circumstances
Old 9th August 2014, 01:10 PM   #10
That's my thinking as well. I have an idea that will put the slots on the corner of the baffle....it'll kinda resemble an Onken cab. Doing this while not creating much diffraction will be tricky.
S15: Econowave DSP - a Constant Directivity vs Dipole study gainphile Multi-Way 167 20th February 2015 12:11 PM
Cardioid midrange Audiodidakt Multi-Way 9 17th June 2013 04:55 PM
Cardioid Subwoofer response using PSP instead of DSP bolserst Subwoofers 2 24th September 2010 04:57 PM
Digital Directivity Control ( more Borat insanity ) Borat Multi-Way 0 16th January 2010 11:19 PM
Blending controlled directivity treble with dipole midrange? 454Casull Multi-Way 21 17th September 2005 12:28 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
