Old 13th January 2004, 04:44 AM   #1
Default radical change to a set of kit boxes
I have a speaker kit which i made the boxes for using there sizing
What i would like to do now is change the box completely . I want to make it narrower, taller & deeper but will keep the litres the same . can anyone see any problems . At least one measurement will be changed by 10 percent or more
Also change the ports from front to back of box . if possible put one next to other or one on top of the other .Can anyboby see any problems thanks
Old 13th January 2004, 12:20 PM   #2
paulspencer's Avatar
Assuming it is not a transmission line there should be no problems at all. The thing most likely to have an effect is the baffle width which relates to the baffle step correction in the crossover, but 10% change is certainly not significant.
cheers,
Paul
PS what kit would that be?
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 13th January 2004, 01:11 PM   #3
The kit is the jv 60 from jaycar .I am rebuilding because I am sick of looking at the 2 ports in the front . could you please explain baffle correction how it will effect the box or the crossover .Is it a effect I am likely to hear
Old 13th January 2004, 10:01 PM   #4
As long as you don't change the baffle width significantly the
sound will not change. Siting the ports on the back will sound
slightly better usually.
sreten.
Old 13th January 2004, 10:13 PM   #5
Just had a thought : keep the width similar but bevel the
edges at 45 degrees for a visually much narrower baffle.
sreten.
Old 14th January 2004, 02:37 AM   #6
thanks for the answers .
I was planning on rounding the edges off as well .
Is there a bad spot to mount the ports for ex directly behind a driver or too close to each other . mabey one directly on top the other ?
Old 14th January 2004, 02:52 AM   #7
The JV60 box is not tall enough. Ideally, the height should place the tweeter on ear level when in your seating position. 900mm is usually about right for a normal couch, so the box should be taller, say 1150 - 1200mm tall. Tall and slim also looks better. If you place the vents on the rear of the box, you need clearance behind as if the gap is too small, the effective tuning of the vents will be lower. Don't worry about baffle width, the difference should be more theoretical rather than noticeable.
IMO the Jaycar box has very bland looking proportions. It is ridiculous to have to put a floorstanding speaker on a stand to get the right height as well. 210mm front baffle width looks about right for these speakers. But this may not help if you are only making minor modifications to an existing box.
What is the size of the box you have now?
Old 14th January 2004, 07:48 AM   #8
With ports the main thing you have to watch is the clearance around it. If it is very near the floor, then this will extend the effective length and you must allow for this. I'm not sure of the effect of placing the vents close to each other. Unless you can get a clear answer on that I'd avoid it.
As far as rounding the edges, I would consider that primarily an aesthetic change, rather than an acoustic one. It is commonly thought to reduce edge diffraction, but I don't think it is really effective. There is a relationship between the wavelenth of concern and the radius of the curve, which means that the radius you are likely to use is only going to work for the very high frequencies which tend to beam and have very little off axis output anyway. If you want to put on a grille, this radius becomes a pest, and personally I don't think the radius looks as good, but that is a matter of opinion.
regards,
Paul
Old 14th January 2004, 10:56 AM   #9
at the moment the box is 275 w external .jaycar say it should be 223 internal .the 210 mm you suggest is close to what i wanted maybe a bit smaller [ internal i mean ]
Old 15th January 2004, 08:36 AM   #10
The main thing is to keep the same volume. The Jaycar box isn't very well braced, especially considering the dimensions used.
Help Me Clone this Radical Speaker Ben Reginato Multi-Way 2 4th March 2008 10:05 AM
Ready to design a radical box! Zac_cutt Car Audio 9 29th September 2006 08:01 PM
Radical PCB design concept SY Everything Else 3 10th August 2004 07:31 AM
Radical (insane) PSU ideas Fuling Tubes / Valves 21 5th July 2004 05:32 AM
Radical new voltage feedback op-amps Petter Solid State 8 31st July 2002 11:45 PM
Page generated in 0.10021 seconds (79.36% PHP - 20.64% MySQL) with 10 queries
