The Tablet Cinema- little something I've been working on. - diyAudio
Old 9th July 2014, 10:32 PM   #1
Default The Tablet Cinema- little something I've been working on.
Here's a little ( real little ) something I've been working on for the last week. I call it the Tablet Cinema....
Small speaker to set my tablet on top of to watch a movie out back with decent sound. I have used The Pipe a few times, but with the huge dynamic range of movies it can be a little to much sometimes ( It's awesome, but can annoy the neighbours ). So, I decided to build something a little ( a lot ) smaller.
I'm using a tiny 2.1 channel amp I found at AliExpress ( about 20 watts to the sub, 10 watts left and right ) to power 2 Dayton ND65-8 as the sub and an Aura Cougar on the left and right, drivers from Parts Express. The Cougars each have their own tiny sealed enclosure and are mounted to a slightly curved baffle to improve dispersion a little ( also helps with comb filtering, but that's not really a concern, this is designed for close listening ) . The Daytons are wired in series ( 16 ohm load ) in a vented enclosure tuned to about 50 Hz ( modeled, I need to run the impedance to verify that ). The woofers ( can I really call a 2 inch a sub? It is crossed over around 150 Hz ) are mounted on the bottom, I still haven't figured out how I want to protect them. The whole bottom panel is removable to make for easy access to everything. Here's a look inside....
Check out the 3/8 " x 1 1/2 " flared vent....
Subwoofer grills...
I still meet to come up with something to protect the full ranges, some feet, how to finish it.
Here's the measured frequency response @ 4 feet from the front ( good listening position )..... This was at about 1/2 volume, I have some excursion issue around 40 Hz ( on a 2", ha! Not even bottoming out, just sounds ugly )... A high pass ( cap in series ) filter should take care of that. Then I can get some good measurements at full volume.
Pretty amazing for an 11" x 9" x 2" speaker really! Not quite THX standards, but not bad.
By the way, so far it sounds great! Huge sound from a tiny box.... Fun stuff!
Chris
Using 2 x Meanwell SMPS to get +ve 0v -ve firestorm Power Supplies 15 5th March 2012 02:42 AM
why would +ve regulator output -ve voltage? ? mrwireless Analog Line Level 12 24th June 2011 03:39 PM
Inverting regulator (-ve rail from +ve supply) - current requirements? peskywinnets Solid State 10 7th October 2010 01:53 PM
What I've been working on for the past week... cyberspyder Headphone Systems 1 21st March 2010 08:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
