Dummy needs help. Which terminal ears do I connect to? - diyAudio
Old 1st July 2014, 09:24 PM   #1
Ramie is offline Ramie  United States
Default Dummy needs help. Which terminal ears do I connect to?
I just re-foamed my Cerwin Vega R12's (1978) and when putting everything back together I suddenly noticed there are two sets of ears on each terminal. D'oh! I think the wires came off the top set (red arrows in picture)... but I already put one speaker back together using the blue ears... (have not tried anything out yet).
So before I do the last speaker and plug anything in... do I need to use the red (top) ears? This is just a standard stereo hookup, nothing fancy. The speakers are two-way speakers if that makes a diff. Thanks guys!
View image: CV R12
Old 1st July 2014, 10:19 PM   #2
KatieandDad's Avatar
I think you will find that it makes no difference.
Old 2nd July 2014, 12:35 AM   #3
That's the answer I was hoping for! Thanks.
2 wires for Return Terminal and 1 wire for (+) Terminal in EXPENSIVE Headphone cable Hallucinogen Headphone Systems 14 24th April 2014 08:21 PM
How old are your ears? davym Everything Else 7 17th August 2013 12:48 AM
3 terminal regulator with 3 terminal shunt reference BWRX Power Supplies 11 17th January 2013 09:08 AM
to where do I connect the grounding terminal of an IEC connector? diymixer Power Supplies 27 30th November 2010 05:39 PM
Copyright 1999-2017 diyAudio
