What to do with a large broken JVC Loudspeaker cabinet?
Old 29th June 2014, 12:37 AM   #1
YashN is offline YashN  Canada
Thumbs up What to do with a large broken JVC Loudspeaker cabinet?
Found this large JVC loudspeaker cabinet outside and wondering what to do with it.
You can see all the drivers have been mutilated and there's only their driver frames left:
What to do with a large broken JVC Loudspeaker cabinet?-jvc-loudspeaker-jpg
The back MDF panel has a large hole in it:
What to do with a large broken JVC Loudspeaker cabinet?-jvc-loudspeaker-2-jpg
I am wondering whether I can re-build a single cabinet from it and put my Logitech subwoofer driver in it instead of its current enclosure. Also wondering whether there's a good way to repair that MDF hole or if it's preferable to just make a new MDF panel to go with it.
Suggestions are most welcome.
Old 29th June 2014, 12:40 AM   #2
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
You should have left it "outside" where it belongs.
jeff
Old 29th June 2014, 12:46 AM   #3
phivates is offline phivates  United States
X2 it's junk
Old 29th June 2014, 12:49 AM   #4
The question is what can I build with it now that I have it, at least as a partial MDF enclosure.
Old 29th June 2014, 01:18 AM   #5
geraldfryjr is offline geraldfryjr  United States
Its free wood !!
jer
Old 29th June 2014, 04:54 AM   #6
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Strip the drivers and parts and chuck tha box away IMO
The driver frames make good places to hang invoices and bills from using a second magnet in reverse{ tweeters}
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 29th June 2014, 07:02 AM   #7
Inductor is offline Inductor  Portugal
Inductor's Avatar
You're lucky you didn't pay for it. This way you don't have to pay a lawyer to get your money back.
Old 29th June 2014, 07:27 AM   #8
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Measure the Logitech's TS parameters and then simulate so you know
if it would be worth repairing.
Making a new panel would seem to me too much of a trouble. Take a piece
of panel larger than the hole, set it over the hole and make a marking so you
know where your router should go. Make a rebate for flush mounting a new
panel. Your new piece would have to be less thick than original depending
on routing depth.
I don't know if that makes any sense to you.
Good opportunities usually come disguised as hard work, so most of the people don't recognize these.
Old 29th June 2014, 07:32 AM   #9
doctordata is offline doctordata  Australia
doctordata's Avatar
Default Pretty cold there in winter !
Best purpose for this cabinets is firewood , gives you the highest efficiency in recycling them ! Chipboard burns like Hell !
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 29th June 2014, 09:18 AM   #10
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Well, the boxes are salvageable inasmuch as you could patch them up. But if you're planning on dropping your Logitech sub in them, a number of points come up:
-You'll need to ascertain if the Vb of the patched up enclosure is appropriate for said sub, and adjust the tuning appropriately.
-You'll need to fabricate new front & rear baffles assuming you want a vaguely attractive finish.
-Again, assuming a vaguely attractive finish, you'll probably spend more time & effort patching up the clapped-out JBL boxes than you would building a new cabinet. Especially since (if you have any specs. for your Logitech unit) you will have more flexibility to adjust volume & tuning, and can probably build a better / stronger / stiffer cabinet.
-With the above in mind, frankly, I'd break them up, unless you just want to have a bit of fun experimenting with the Logitech in a different volume. The balance sheet comes down in that direction. You might be able to salvage some of the material so it's not wasted.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
What to do with a large broken JVC Loudspeaker cabinet?Hide this!Advertise here!
Econowave with large cabinet. cocolema Multi-Way 1 14th May 2012 10:03 PM
JVC AX-Z1010 repair, resonator broken? Help? ric-paul Solid State 15 23rd April 2012 08:07 PM
JVC AX-Z911 right ch. broken, caps gone, voltage? TuomasH Solid State 11 9th July 2011 09:16 PM
Trends in Loudspeaker Cabinet _henry_ Multi-Way 3 9th February 2009 11:59 AM
Copyright ©1999-2017 diyAudio
