Would it be possible to run a 6 ohm speaker on an 8 ohm amp? There would only be one speaker (center in home cinema) and the speaker is made by Yamaha, and the amp is a quite cheap JVC.
Thanks for any help |
#2 |
should be OK,
#3 |
I agree with sreten. Connecting an amplifier rated for an 8-ohm load to a 6-ohm speaker should be just fine. I wouldn't worry until I dip below 4-ohm loads.
#4 | |
diyAudio Senior Member
What you have is an amplifier with a power rating into a given load, often measured as 8 or four Ohm. A transistor amp with a given power rating for an 8 Ohm load will produce slightly more power into a 6 or 4 Ohm load and so on. Lemme guess, this is one of these TXxxx range hometheatre amps from JVC? Cheers,
Frank |
#5 |
Yeah it is a JVC home theatre amp from the TX range. Very cheap @ £99 and it has loads of features for the price. I am looking to upgrade soon. Are those JVC ones not very good then!
#6 |
can you tell me what ohms 4 and 8 ohm speakers connected speakers in parralell
#7 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 | |
frugal-phile(tm)
2 2/3 ohms dave
| dimentions of speaker box in speaker spec sheet? | Dan2 | Car Audio | 2 | 6th February 2009 05:34 AM |
| Mounting speaker. Speaker gasket? | Cal Weldon | Multi-Way | 0 | 11th April 2007 10:36 PM |
| FS: Niles HDS-6L speaker selector w/ speaker protection. | Spasticteapot | Swap Meet | 0 | 27th May 2006 11:14 PM |
| New Ribbon Speaker Technology - Approach the perfect speaker? | cocolino | Planars & Exotics | 49 | 16th January 2005 10:12 PM |
| Pi Speaker Reviews/or Similar Speaker | G4ME | Multi-Way | 4 | 17th June 2003 12:26 AM |
| Page generated in 0.09310 seconds (77.74% PHP - 22.26% MySQL) with 10 queries |
