Under Cabinet enclosure with Lepai LP-2020A+ - diyAudio
Old 23rd June 2014, 10:15 PM   #1
Default Under Cabinet enclosure with Lepai LP-2020A+
Hello,
I bought a Lepai LP-2020A+ and am interested in pairing it with some drivers in my kitchen. I would like to build an enclosure that fits under my cabinet and that is low profile. Ideally I would like it to be around 3 inches high, but length and depth aren't really an issue.
I would love
a) recommendations for drivers that would work with the Lepai LP-2020A+
b) any sort of guidance on building an enclosure that thin.
Thanks!
Old 24th June 2014, 02:24 AM   #2
mikje is offline mikje  United States
Soakin' up the Sound!
mikje's Avatar
Although this is taller/higher than three inches, you could adjust the dimensions as long as you keep the volume the same. It would work well for music in the kitchen with the Lepai.
https://sites.google.com/site/undefinition/sprite
This is another alternative
Master Nagaoka Tetsuo explorations on matrixed single stereo speakers
What is your budget for speakers? There are a number of 3 inch drivers that could be made to work with Lepai.
Mike
Marantz PM8003 amp, Jolida SJ502A, Squeezebox Touch, MLTL Continuums, DIY Carmichaels (Dayton, TangBand, Vifa); MarkAudio A 7.3 Frugalhorns, MarkAudio CHP-70s
Old 24th June 2014, 05:27 PM   #3
Inductor's Avatar
A really nice “antishock” implementation for good source of ideas is the Philips BR-1X
Old 25th June 2014, 05:53 AM   #4
Awesome. Thank you for the response. If like to spend around $100. I was interested in building a t line enclosure. I thought it might be a good choice since the drivers are so small
Old 25th June 2014, 06:06 AM   #5
picowallspeaker's Avatar
Funny, by reading about those bluetooth devices, the specs don't exactly tell if the sound is treated as stereo or is processed into mono, after the input jack.
Old 25th June 2014, 10:50 AM   #6
Inductor's Avatar
Have no idea, but it could also be a 2.1 since it has a parasub in the back.
Another interesting implement of a design.
https://www.kickstarter.com/projects...rting-the-reta
Dead Lepai Tripath LP-2020A+ ? etemplin Class D 5 11th January 2014 06:53 PM
Lepai LP-2020A+ DC offset survey lorriman Class D 13 19th June 2013 09:44 PM
Lepai LP-2020A+ Vs. Lepai LP-168HA. Biggie1494 Class D 3 15th March 2013 05:03 AM
Help with Lepai LP-2020a+ ChrisChris Class D 5 14th September 2012 03:24 PM
Lepai LP-2020A+ Balance Problem Nightcry7 Class D 3 14th September 2012 03:16 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
