The "Golden" Ratio?
The "Golden" Ratio?
Old 11th January 2004, 08:27 PM   #11
Christer is offline Christer  Sweden
Default Re: Fibonacci
Originally posted by janneman
If I can pick your brain a bit more, the reason for the use of golden ratio's in speaker dimensions is that it would avoid standing waves appearing of the same wavelength or multiples of it in more than one dimension. Meaning that there should not be a standing wave in the width of say L, while at the same time there would be a standing wave of 2L in one of the other dimensions, L of course being determined by the fact that it would be an integral of the dimension.
Do you agree that this golden ratio in speaker dimensions is a good one to avoid these multiple-wavelength standing waves? Could there be a better one?
Yes, I thought that was the reason. Or rather, I suppose we
want to find a relationship s.t. for each pair a,b of the three sides
of the box, we never have the case that both a and b are both a
multiple of the wavelength for any frequency in the audio band.
Or maybe multiple of half the wavelength is more appropriate?
It's been very long since I took the course on wave propagation.
I don't know if the golden ratio is guaranteed to achieve this
and if so if it is the only number achieveing it. If it does not
guarantee this condition, then maybe it is still the best choice
or maybe it isn't really known if that is the case. I am not a
mathematician so I have no clever answer here. However, I
wouldn't be the least surprised if it has been proven that the
golden ratio is the optimal value. That number as well as the
Fibonacci series has an almost magical tendency to appear even
where you least expect it.
Then, let's not forget that this is only the theory and since
element positions must be taken into account,
elements are not mathematical points etc. the best practical
values may very well be off from the theoretical best ones.
Originally posted by Steven
Some fiddling around with this equation shows that b:a = 2/(sqrt(5)-1) which is 1.6180339887498948482045868343656.
This requires an highly accurate sawing-machine and skills.
You ought to get yourself a better sawing-machine, then you may
use this approximation instead
http://www.cs.arizona.edu/icon/oddsends/phi.htm
Edit: As i said, the golden ratio has a tendency to show up
http://www.golden-ratio.co.uk/
Old 11th January 2004, 08:54 PM   #12
R.I.P.
I'm not so sure about that. Are you talking about filling the internal space with damping material like sheeps wool etc?
Jan Didden
Well I'm pretty sure. If you can't measure it its not there. Acoustic
damping in speakers is very effective at the wavelengths that are
relevant. Its only an issue with minimal internal acoustic damping.
sreten.
Old 11th January 2004, 09:07 PM   #13
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
I suggest reading this thread
You may also find this useful to calculate enclosure/room modes.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 11th January 2004, 09:32 PM   #14
GM is offline GM  United States
GM's Avatar
>If you dont like this shape then you play around by halving one ratio :
giving h=1.6, w=1, d=1.3, suitable for a two way.
Right, while the golden ratio collapses at the 8th harmonic, this one makes it to the 10th.
>According to the radio shack book i have you can use either
.6 : 1 : 1.6
or
.79 : 1 : 1.25
There's actually numerous acceptable acoustic ratios, some better than the golden ratio, but in most cases, any ratio that works out to the 4th or 5th harmonic is sufficient.
The asthetically pleasing 1:1.4:2 often seen in architecture is good to the 11th harmonic, and 1:1.26:1.41, 1:1.17:1.47, and 1:1.45:2.10 are (were?) popular speaker cab ratios.
If you can find a copy of Bolt, Beranek, and Newman's acceptable room ratio graph you can choose many more, or just plug whatever numbers you want to use in a room mode calculator to see how well they work.
>The ratios are much more applicable to room modes in acoustics.
In speakers you can damp the internal modes into insignificance.
I agree it's moot WRT the typical small two way monitors currently in vogue, but this often requires too much stuffing IMO if 'fullrange' drivers are used and/or the cab is fairly large.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th January 2004, 10:33 PM   #15
uvodee is offline uvodee
uvodee's Avatar
Originally posted by Christer
The golden ratio has a strange tendency to pop up in various situations as diverse as art, optimizing
certain data structures for computer programs and, obviously,
loudspeaker design. BTW, Fibonacci invented his number series
in an attempt to find a mathematical model for how quickly
rabbits multiply.
You are so right, my friend, and that the television industry is not following this rule by 'inventing 16/9 format explains immediately why lookin nowadays tv screens give you unnatural looks, and actually tires you out when trying to see the picture.
Jean-Pierre
Old 15th January 2004, 10:14 PM   #16
coolkhoa is offline coolkhoa  United States
coolkhoa's Avatar
Send a message via AIM to coolkhoa Send a message via MSN to coolkhoa Send a message via Yahoo to coolkhoa
Default Small speakers ignore "golden" ratio?
I've realized that most small speakers ignore the golden ratio altogether (either for aesthetics or because of the fact that using such a ratio means the driver(s) cannot fit on the front panel). In fact, I've seen small speakers that are square or are nearly square in two dimensions (usually width and depth).
My question is: does an enclosure with a dimension 1.5 times larger than another just as bad?
KTK. Kool To the Kore.
Old 15th January 2004, 11:49 PM   #17
Vikash's Avatar
Just as bad as what? Any dimension which is a the same as another will have the same standing wave fundamental and harmonics. A dimension which is easily divisble by another dimension will have some clashing standing wave harmormics. So 1.5 times is not as bad as having two the same, but is bad nevertheless.
See how the 2nd and 3d, 4th and 6th harmonics clash for your 1.5 times example. But it's not nearly as bad as having two dimensions equal
The smaller the dimension, the higher the standing wave frequencies. At 7cm for example, the standing wave fundamental is 2.4kHz. I think (though not sure) that for a reason related to the high frequency, small enclsosures do not have the same concern of standing waves (less enegry perhaps = more easily suppressed by stuffing/frequency handled by tweeter?)
Old 16th January 2004, 10:46 PM   #18
sardonx is offline sardonx  Canada
"Thanks for the interesting info here, everyone. Maybe I'll have to look into devising my own ratio for each type of speaker (i.e. mini monitor, dual-woofer, etc.). About that Radio Shack book, sardonx, I probably have the older edition..."
I have Advanced Speaker Systems from radio shack.. and yeah i guess this might be newer than the one you have because i had one before this too... an older version (probably the one you have) but it got torn apart from laying around the floor too long.. lol. This book teaches lots of stuff.. nothing too in-depth but a useful book to have.
The End
Old 17th January 2004, 09:45 AM   #19
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
The "Golden" Ratio?
The Golden Ratio is just an especially pleasing irrational number... irrational numbers are your friends.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th January 2004, 02:12 PM   #20
markp is offline markp  United States
dave
But irrational people are not!
If it sounds good... it is good!
The "Golden" Ratio?Hide this!Advertise here!
The Golden Ratio Stage Stee Solid State 7 22nd February 2009 09:46 PM
question regarding "golden ratio" Jeb-D. Full Range 3 28th May 2006 11:39 AM
W4-1320SB Golden Ratio BR sharpi31 Full Range 4 8th December 2005 10:50 PM
Golden Box Ratio - Important or not? Ornlu Subwoofers 5 27th May 2005 07:52 AM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 09:40 PM
Copyright ©1999-2017 diyAudio
