Visaton W250S - diyAudio
Old 19th June 2014, 06:30 AM   #1
Default Visaton W250S
These are reasonably priced in Aus & good efficiency
anyone used them, or got any measurements?
cheers,
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 19th June 2014, 10:28 AM   #2
system7 is offline system7  United Kingdom
system7's Avatar
It's a very well documented driver: W 250 S - 8 Ohm
It's OK up to about 2kHz from my estimates. You can model it too: Downloads
The only aspect that you might consider is that it has a pressed steel chassis. If you want a less coloured cast chassis, look around for stuff like this: H1305-08 CA26RFX
Well, there it is! Best regards from Steve in Portsmouth, UK.
Old 19th June 2014, 11:24 AM   #3
re:"look around for stuff like this:" - if only SEAS drivers were available locally any more... freight for big drivers to Aus is a killer for a tightwad like me, & I prefer to source locally.
Looking for some serious woof, 2x 8" SB might be more effective, or I might throw caution to the wind and buy a couple of cheap 15"ers
My mids will be the last of the pre-chinese 5" Peerless 850488, & Peerless tweeter from the same era, really nice low distortion drivers
Old 19th June 2014, 03:32 PM   #4
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Pete,
I had them measured once. Decent and simple drivers.
Have to see if I can come up with some more plots.
Old 19th June 2014, 10:03 PM   #5
frangus is offline frangus  Australia
Pete, what about peerless, vifa and scan speak classic line. They are available locally for decent prices
Old 20th June 2014, 12:21 AM   #6
Thanks Lojzek
Frangus - Scanspeak - overpriced (told you I was tight), Peerless, about the same price as the Visatons, & I've already got a pair of the old 850149s, damn good, but I want to try something else, (Undecided whether to go small, 8" a la 3 way classic, or Monster, 15" drivers. Don't really need another set of speakers, but it's a shame to let those peerless mids/tweeters gather dust in the shed)
Old 20th June 2014, 06:30 AM   #7
Zvu is offline Zvu  Serbia
Zvu's Avatar
Originally Posted by Lojzek View Post
Pete,
Lojzek, did you use delta mass or delta compliance test for generating TS parameters ?
East side baby
Old 20th June 2014, 07:09 AM   #8
Lojzek's Avatar
Zvuchniak,
I use weights for TS parameters.
Visaton screws ermat1234 Parts 0 2nd February 2013 09:59 PM
visaton lejaybo Multi-Way 21 2nd February 2009 05:24 PM
Visaton B20 breitband Full Range 1 10th January 2006 09:17 PM
"Visaton - is it worth?" or... "Share your Visaton experience" mr_push_pull Multi-Way 10 7th August 2004 06:18 PM
Visaton shadow Multi-Way 6 16th June 2002 09:27 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
