hello all,
sorry to bother you guys with this newbie question but here i go....
I am planning to build a sub to match my speakers. Building an amp and the sub itself won't pose a problem (i think )
Designing a crossover, however, will be as I have never done this.
Any hints/links to suggested reading/schematics ? I've been searching for a couple of hours now but almost everything I find is either pretty complicated (for a newbie to filter design anyways) OR has something to do with digital filters.
A "howto - build passive xo's" would be great...
What i'd really like is a variable passive xo.
Matjans,
Checkout Rod Elliot's writeup in x-over design here:
http://sound.westhost.com/lr-passive.htm
The problem with passive x-overs for subs is the components need to be very large (read $$expensive$$). Than to try and make it variable on top of that will send you to the poor house. You can get much better results from bi-amping with an active x-over for not much more money (depending on what you buy).
Crossovers for subs are usuall in the 70-120Hz range. For a passive network the inductor values are large, the losses high and the expense high.
It is more practical to bi-amp and for this you'll be looking at active crossovers. They are easy to calculate and build and I believe there are some PC boards available. I don't have the proper links but I'm sure someone can jump in here and provide them.
There is no such thing as a variable passive crossover.
This one was designed by the Pass Labs crew.
http://www.vidsonix.com/vidsonixnew/vidsonix_audio4ind.htm
here is a good link to get you going on active crossovers:
http://www.linkwitzlab.com/filters.htm
matjans said:i see that my first post was pretty unclear.
I am building a separate sub for HT purposes. All i need info on is a line-level filter design. Be that active or not.
I'll bridge an opa or a lm3886 or anything as an amp.
sorry for the confusion
Doesn't your av receiver have a built in x/o ?
Rob
Hi, I want to build a sub crossover too, and was wondering if this would work. It is off the site Joe Dirt sent us to. I would build it as just a lowpass, not even building the highpass part. Would the frequency cutoff be 99hz as in the schematic, or is that something else?
Thanks, Mike
Thanks, Mike
Ok in that case the link to the linkwitz site given above will give you most info you need for opamp based x/o.
Also look at this site - John doesn't seem to be answering e-mails but theres lots of info there:
http://www.snippets.org/filters/crossover.htm
Good luck!
Rob
Good luck!
Rob
Matjans,
Ohh, line-level. Here a site that can help with a PLLXO.
http://www.t-linespeakers.org/tech/filters/passiveHLxo.html
If you're really sharp you'll recognize the home page of one of our more prominent members.
Take a look at Rod Elliot's site for information and boards for some simple active line-level filters. The xover stuff is here:
http://sound.westhost.com/projects-3.htm
I use a first order PLLXO as a hi-pass to the mid-bass and a third order active lo-pass for the sub. Beyond a second order PLLXO and the losses become too high.
- sub xo design questions
