diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   8 Ohm projects?? (http://www.diyaudio.com/forums/multi-way/25780-8-ohm-projects.html)
bbksv 10th January 2004 11:50 PM
8 Ohm projects??
I have been looking around alot for a good project but it seems everything that looks good...is 4 ohm. Are there any good 8 ohm projects around with decent efficiency....for under about $500 usd a set???
osey 11th January 2004 12:48 AM
Any project suitable for 4 ohm operation, will work with an 8 ohm load as well. Just not the other way around.
Afraid I cant suggest any 8 ohm projects as a kit, but amybe a p3a amp from Rod Eliotts pages would do with a pair of 2 way bookshelfs. They wont be too hard to design well.
sreten 11th January 2004 01:13 AM
You are correct, most highish efficiency designs are 4 ohm nominal, usually
by the expedient of parallel twin 8 ohm bass/mid drivers, MTM or MMT.
(note :
voltage sensitivity of twin drivers is +6dB, +3db by shared
acoustic loading and +3dB by the impedance being halved.)
What do you mean by decent efficiency ? given baffle step correction ?
Basically you need a decent sized 8 ohm single bass driver or
series paired 4 ohm twin bass units, not particularly popular.
:) sreten.
Resources saved on this page: MySQL 18.75%
