Klpisch LaScalla/Lowering midrange output with a resister - diyAudio
Old 3rd June 2014, 08:49 PM   #1
Default Klpisch LaScalla/Lowering midrange output with a resister
Hi, I have been reading about modifications to my klipsch LaScala speakers and came across a comment about: just put "a 15 ohm resistor in parallel with the driver" ... Does that mean between the positive and negative leads to the mid horn between the crossover and the driver?Or does it mean to put the resister in line on the positive lead to the mid horn ? thank you for your time and tolerance.This is supposed to lower the midrange by about 3 db. I am also building a bass mod cabinet for them to sit on.
Old 3rd June 2014, 08:55 PM   #2
IMHO the midrange is the best part of the LaScala. The low end only goes down to 50Hz which is what is lacking. Which is why the CornScala was invented.
Cornscala? | Critesspeakers.com
Parallel means put the resistor across the + and - of the driver. But I would think that would do the opposite of what you want.
Old 3rd June 2014, 09:06 PM   #3
You would do yourself a favor by telling us which crossover you have and also posting a schematic. As I recall most of those crossovers used an autoformer on the midrange. Using a diiferent tap would be the most straightforward method (this may also require adding a resistor). Again, tell us which model crossover and provide a schematic (they are posted on the Klipsch forum)
Old 4th June 2014, 01:19 AM   #4
HI,Famousmockingbird and With Tarragon I have a pair of 1971 LaScala with the type A A crossover and I used a cap set two years ago from Bob Crites .I am computer challenged and don't know how to down load and then reload the schematics .But i would like to try to turn down the mid horn 3 db just to see.I did alot of room acoustic work.I have too small a room for the LaScala but they sound better than two weeks ago.... soooo yes I agree the midrange is great but i want to try less,I have heard it said in some smaller rooms this "15 ohm resister in parallel"can be a dramatic improvement [with the right room response]I hope I can try this out.Thank you Scott In eugene oregon man the garden is taking off
Old 4th June 2014, 04:04 AM   #5
GM is offline GM  United States
GM's Avatar
No experience with these, but here's a thread with some info about how to do it: La Scala - Crossover Mod to Take Squawker Down -3dB - AudioKarma.org Home Audio Stereo Discussion Forums
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 4th June 2014, 08:55 AM   #6
LTD Co is offline LTD Co  United States
Banned
there is T2A auto-trans on the XOver. just lower the mid-range tap and there would be no need to a resistor.
Old 4th June 2014, 06:30 PM   #7
some of the old klipsch have horrible horns
Klipsch loudspeaker corner
Old 5th June 2014, 11:42 PM   #8
Yes, LTD Co I don,t know what you mean by "just lower the mid-range tap". Could that be shown in a picture or would that require equipment to measure frequency? Thank you so much for your response .Scott in Eugene Oregon
Old 6th June 2014, 12:53 AM   #9
If you are saying that technolgy has improved in the past 40 years, then yes you are probably correct
Old 6th June 2014, 12:56 AM   #10
There are a series of outputs on the autoformer. Just move the connection. Ask over at the Klipsch forum.
It is not difficult
Lowering the output impdance of the TSSA V1.6 sonnya SITO Audio 3 18th June 2014 07:07 PM
Roll off midrange acoustically by lowering box volume Cousin Billy Multi-Way 14 19th December 2008 05:32 PM
Lowering voltage output of transformer TGRANT Tubes / Valves 8 17th January 2007 10:29 AM
Lowering the output impedence of this dac's output georgehifi Digital Source 14 31st October 2006 07:05 PM
Lowering clock output audiokid25 Digital Source 4 6th June 2005 07:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
