Anyone who has "Yamaha" speaker please come here. - diyAudio
Old 19th May 2014, 01:53 PM   #1
Default Anyone who has "Yamaha" speaker please come here.
I've noticed something weird on the Japanese 1980s Yamaha speaker. Usually, any speaker drivers would have their "positive" terminal on the right and "negative" terminal on the left of their voice coil when placing them faced with the magnet (You can see on your drivers). But from my observation, those 80s Yamaha speaker; ns-10/m, ns-20, ns-100/m, etc. and also 80s JBL speaker, were placed their voice coil terminal in opposite to the usual drivers. (See attached image and compare to your own speaker)
For JBL, I don't doubt at all because there has been announced from JBL that their speakers are Negative-type. You can find out on this link http://www.jblpro.com/pub/technote/tn_v1n12b.pdf or you can type"jbl reversed polarity speaker"in google for more information.
So, I want a hand from one who has those vintage yamaha to examine the polarity by using a 1.5V battery connecting to + (red) terminal. If they are really be a negative-type, the cone should move "in" when connecting to + of battery while the usual speaker should move "out". IMHO
Thank you
Attached image :
image 1 : ns-10m woofer
image 2 : ns-10 woofer
image 3 : ns-20m tweeter
image 4 : ns-20m woofer
image 5 : ns-10mx drivers
image 6 : ns-1000m woofer
Old 19th May 2014, 02:27 PM   #2
system7 is offline system7  United Kingdom
system7's Avatar
presscot, you risk driving yourself crazy with this obsession!
There is NO CONVENTION on left or right with speaker terminals. That's why manufacturers use a red dot or a fatter spade terminal to denote positive, which by convention causes the speaker to move forward when connected to a 1.5V battery positive terminal.
But don't try that with a ribbon tweeter, you might blow it.
Well, there it is! Best regards from Steve in Portsmouth, UK.
Old 19th May 2014, 03:15 PM   #3
System7,
No. Can't you see in your attached pictures , your Visaton drivers are + sign, and red spot or fatter spade, on right-terminal while looking in my attached pictures, the Yamaha's are on the left.
Old 19th May 2014, 03:22 PM   #4
Speakerholic
Cal Weldon's Avatar
presscot, the Morel tweeter on Steve's 3rd pic is on the left, if the magnet were facing you.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 20th May 2014, 12:50 AM   #5
CLS is offline CLS  Taiwan
I remember I've checked the polarity before wiring and they should act normal (+ to + for pushing out / retreating for the other ).
I'll check it again.
Old 20th May 2014, 01:30 AM   #6
chrisb is offline chrisb  Canada
Battery test to detect forward motion is certainly easy enough for larger cones, but domes and small cone tweeters with fraction of mm x-max could be rather more tricky?
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 20th May 2014, 02:02 AM   #7
DUG is offline DUG  Canada
Equipment:
Battery
Capacitor
Microphone
Oscilloscope
Method:
Test pulse polarity response of mic and scope with known woofer.
Charge cap with battery and discharge into tweeter.
Observe pulse response on scope.
Simple.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 20th May 2014, 03:35 AM   #8
In my experience, the motion of dome tweeter is still visible in battery test.
Only a little, yes, but visible.
Not sure for compression drivers.
Old 20th May 2014, 03:41 PM   #9
Besides classic JBL and Tannoy were there any other manufacturers who designed drivers so the cone moves back when faced with a positive voltage?
Just being curious...
Old 21st May 2014, 01:57 AM   #10
Aha, I do doubt too.
Yamaha M-85 Bias Voltage Does Not Increase In "Auto A" Switch Position 69sixpackbee Solid State 11 11th March 2014 08:42 PM
12" feild coil speaker "WOW" AF Froger Instruments and Amps 11 23rd June 2012 03:03 AM
Yamaha's kind of ERCO: Zero Distortion Rule "ZDR" (M50, M70, A520) tiefbassuebertr Solid State 3 28th October 2010 07:44 AM
Where to buy "Yamaha M-85" style red LED diodes? Spilferderber Solid State 12 20th December 2006 07:56 AM
10" basS/mid for "party-speaker" TroelsM Multi-Way 0 16th September 2005 11:14 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
