Seos 12 + Faital Pro two ways.... - diyAudio
Old 8th May 2014, 04:44 PM   #1
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
Default Seos 12 + Faital Pro two ways....
So, after I finished my DIY Synergy horns I got a commission for some two way speakers to go with a EL-34 based tube amp. The SEOS12 horns came to mind, first and then it moved on from there.
I paired the horns to the same PRV D290's I used in my Synergy's...and for the woofer I picked a Faital Pro 12FH520.
The bass alignment is a moderate EBS, I'm at work so I don't remember exact volume/tuning frequency. In room the speakers reach into the high 30's...with an extremely tight sound.
Still not done tuning the crossover yet, I've done a ton of emulations using SoundEasy.
I thought I'd post a bit about tuning crossovers....which involves juggling a ton of different parameters.
http://speakerscott.tumblr.com/
Old 8th May 2014, 04:50 PM   #2
Default Lots of crossovers...
So I've done a lot of crossovers for this thing...probably hundreds of minor revisions and 30-40 major revisions.
These two pictures show the frequency response and crossover transfer functions of one of the first crossovers, and one of the last, which is highly likely to be the final crossover. (If it's not the final, I believe it'll just be fine tuning some values.)
I compare the frequency response of the two designs to show the similarity of the frequency response even though the crossovers are completely different. The sound of the two designs is also completely different. The first, with the lower crossover pushed the tweeter a little too hard in the upper mid-range leading to harshness especially on male voices, and anything with a trombone.
For Frequency response Red = low crossover point, Green = high crossover point.
Old 8th May 2014, 04:55 PM   #3
Even within a given crossover topology and transfer function there is opportunity for adjustment. Knowing that this was going to be powered by a tube amp I wanted to keep the impedance reasonable across the board. The first version of the higher crossover point I did rolled off in impedance starting at roughly 3kHz dropping as low as 4.8 ohms. I wanted to keep that above 6 ohms to make best use of the 8 ohm amp taps as possible.
With a little effort I was able to figure out why the impedance was dropping, adjust values and crossover circuit topology to maintain the same transfer functions and raise impedance.
Old 8th May 2014, 04:58 PM   #4
And finally a few construction pics....the veneer is 1/4" "narrow" grain bamboo. Finished with 8 coats of pre-cat nitrocellulose lacquer with no dyes.
Old 8th May 2014, 06:47 PM   #5
What do the HF/LF acoustic slopes look like?
Old 8th May 2014, 07:49 PM   #6
4'th order Butterworth....ish....sorta....
Scott
Old 8th May 2014, 07:59 PM   #7
Scott
Which if I remember correctly puts them in the L-R family. SoundEasy doesn't allow for 4'th order L-R passives...sigh. Sound$@!*
Old 8th May 2014, 08:00 PM   #8
What is the acoustic xover freq.? Sorry, I should have just said "I'd like to see the acoustic slopes if you don't mind posting them sometime" .
Old 8th May 2014, 08:25 PM   #9
I'll try and post them tonight...I don't have access to that computer right now. Crossover frequency is higher than I had initially intended...~2.4kHz...2.5kHz...don't remember exactly.
Old 8th May 2014, 09:34 PM   #10
That's what I was guessing from the filter. I guess that probably means around a 3-4dB dip off-axis around there*, so do you not wonder if the difference heard was the difference in upper-mid reflected sound levels, rather than a struggling HF driver? I ask because that's happened to me a couple of times with this style of speaker.
*Relatedly, I just reminded myself what the polars for the SEOS 12 look like, and it looks like it has a little bit of a bloom horizontally up there.
AE TD10M (1) or two Faital 8FH200 with SEOS 10/BMS 4550 SpinMonster Multi-Way 63 11th June 2014 02:00 AM
Winter 14 speaker project for sale: faital 140 HF faital 15 PR400 SEOS 24 naca5 Swap Meet 3 11th May 2014 08:14 AM
Faital Pro HF10AK csuflyboy Multi-Way 7 13th December 2013 06:48 AM
Faital Pro 12PR300 + SEOS-12/DNA-360 Comments? mctavish Multi-Way 10 17th November 2013 11:29 AM
WTB: SEOS 12 + Adapters midyim Swap Meet 0 2nd December 2012 08:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
