diyAudio reference speaker project
Old 23rd June 2008, 01:30 PM   #301
jamtin is offline jamtin  Australia
Thanks for the info Rabbitz, good to see another novocastrian here.
I'll have a look at 6.5" drivers as well if the box does'nt need to be much bigger.
Thanks for the tip on the Seas tweeter. Is Aranmar the Aus distributor for Seas ?
Regarding design goals, I noticed that the response in WinISD using the drivers and dimensions specified in the Wiki (9.5L) was a not flat, thought I'd stuffed it up. I dug out your LDG I downloaded a while back and checked out vented box design. Looks like I've got a fair bit more reading to do about alignments etc
I'll move onto the crossover after the driver & box is sorted, so there'll be plenty more questions...
Old 24th June 2008, 04:27 AM   #302
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Yep.... Aramar are the guys for SEAS.
http://www.aranmaracoustics.com.au/
There's quite a few Newcastle guys around here.
When designing a box, you just need to tailor for the response curve and F3 you are after and most times that's not necessarily flat to suit tastes, baffle step or room loading. There are other factors of course such as xmax, power handling, group delay etc and it's about picking the right compromises. Not rocket science and mostly common sense.
Old 7th March 2009, 03:56 PM   #303
johngalt47 is offline johngalt47  United States
Default Finally!
After such a long time I finally finished a "prototype" of these speakers.
In between I built a pair of Jay Kim's speakers using the SB woofer and little Vifa tweeter.
Anyway, I'm impressed with how this little speaker sounds. I used the singular because I've only built one so far. I have the one I just built on one channel and my Dynaudio Contour 1.1 on the other channel. Surprisingly they are a good match for the most part. Their frequency response isn't an exact match but close enough to play around with. I have the back clamped on for now but I'll glue it permanently later.
At first I only had part of the flared tube in the port and there was some harshness. After I added the rest of the tube it sounds great!
Thanks to all who contributed to the design, especially Rabbitz!
Any technology sufficiently advanced is indistinguishable from magic
Old 8th March 2009, 02:47 PM   #304
rabbitz's Avatar
Thanks for your kind words.
Mine are still in use in my office and are the longest serving of my DIY speakers and are also still used as a reference point for new designs. I've changed the tweeter on mine to some Scan Speaks only because I had some left over from another design and is bit of an over kill for the design.... but hey, why not.
No longer DIY active
Old 14th May 2009, 07:35 AM   #305
andrew01 is offline andrew01  Australia
Heya rabbitz,
I have a pair of P13's and some XT25's kicking around that I picked up cheap.
Was thinking I might throw them together in your 'large' wiki reference box.........
Do you have any clues on a x-over for them ?
I was going to try the single 5uF cap but I dont think it will work with the XT25.....
Old 14th May 2009, 08:06 AM   #306
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Try these instead
http://cgi.ebay.com.au/ws/eBayISAPI....m=260395041526
The SEAS tweeters should be easier to work with from recent conversations with Rabbitz
regards
Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 14th May 2009, 08:18 AM   #307
Yeah you're probably right , but , I just wanted to use up what I had in-hand....
Old 14th May 2009, 08:29 AM   #308
Moondog55's Avatar
I have made that same mistake, wanna swap the p-13s for a pair of P-11s, they cross over a bit higher 3.7/4k maybe easier to do.
Ted
Old 14th May 2009, 01:04 PM   #309
rabbitz's Avatar
Originally posted by andrew01
Heya rabbitz,
The 5uF cap will not work with the XT25 for sure as it does need a lot of help in a crossover.... more than I'm prepared to do. Last month I tried the XT25 in this speaker and was not a good match with too many nasties from the XT25 below the crossover point. It looked good by the modeling but didn't match up in reality. I didn't spend too much time on it by adding correction circuits and other fixes.
Dropped in a 27TFF, a redesigned crossover and some tweaks and it's a cracker.... a real smoothy and sweet. The XT25 went to ebay.
Old 14th May 2009, 01:29 PM   #310
rabbitz's Avatar
Ted
When I first read that Ted I thought you wanted to swap some P13s for some P11s.... doh... <puts on glasses>.
The P13 with the 27TFF crosses over just above 3k and has an overlap of over 3 octaves. Allows both drivers to work well within their operating range. I was a bit worried and thought the 27TFF would need to be crossed over higher as it has a highish Fs (2 x XT25) but it handles the frequencies below the crossover point with ease and no nasties.
The XT25 just needs a lot of work and higher orders etc due to it's lower end behaviour. This will give you some idea of what's needed. Without this sort of effort it just doesn't want to roll off and believe me you don't want to hear below 1k on this tweeter.
http://www.troelsgravesen.dk/VifaPL14WJ+XT25TG.htm
http://www.zaphaudio.com/ZD5.html
diyAudio reference speaker projectHide this!Advertise here!
