diyAudio reference speaker project - Page 19 - diyAudio
Old 14th September 2006, 01:27 PM   #181
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
The Wiki has been changed to add a link to the xo schematics, tweeter polarity added and the crossover values altered in line with the current designs.
D27TG / P13WH Wiki
No longer DIY active
Old 14th September 2006, 02:34 PM   #182
MuaDibb is offline MuaDibb  United States
Thanks Rabbitz that was awesome.
Old 14th September 2006, 06:55 PM   #183
frugal-phile(tm)
planet10's Avatar
Good work, now you have me thinking about digging out the VIFAs and loading them into the queue.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th September 2006, 07:26 PM   #184
can someone tell me what the difference is between the p13wh0008 and the p13wh1004?
Im guessing the 4 refers to impedence, but what about the 1?
edit:
nevermind. Car speaker. That changes the question.
Aside from impedance, how would this driver differ from the p13wh0008?
The FR curve looks similar. I dont expect it would be a drop in alternative but with two components it wouldn't be the most difficult thing in the world to figure out.
Im asking because its on sale at solen.
Theres info with a FR curve here:
http://www.madisound.com/pdf/vifacat...p13wh-10-04%22
edit#2: ok nevermind. Its a completely different driver. The TS parameters are completely different. Optimized for off axis listening. Of course if someone wanted to play around, they still have a beautiful FR curve and would probably be really nice to design for.
Old 15th September 2006, 08:38 AM   #185
rabbitz's Avatar
dave
I bet the queue is looooooooooong.
Old 15th September 2006, 09:43 AM   #186
frugal-phile(tm)
planet10's Avatar
Some of the projects in the queue may well outlive me
dave
Old 15th September 2006, 08:03 PM   #187
Quick question, madisound has a D27TG45, but it doesn't look like the tweeter inthe esquire pic. It looks like the D27TG35 thats available at PE and Madisound. It doesn't seem like much difference if any between the two expcept for the faceplate. Which is the correct tweet or could I use either?
Old 16th September 2006, 11:53 AM   #188
rabbitz's Avatar
You could go with either tweeter but I think the D27TG45 is supposed to be a tad better.... not 100% sure.
D27TG35 is used here as no stocks of the D27TG45 left at the distributor in Oz.
Old 16th September 2006, 10:05 PM   #189
contour is offline contour  Netherlands
Today I build the AR series crossover using:
L1 = 0.11 mH
L2 = 1.20 mH
R1 = 6.8 ohm
C1 = 22 uF
For L1 I used a copperfoil inductor. L2 is a Tritec 2.0mm2 coil (coil wire consists out of 6 seperate strings twisted together) R1 is a MOX resistor. I executed C1 as a 400V Audyn MKP in parallel with a 0.1uF 800V Audyn plus.
I also took some pictures of the crossover:
http://img154.imageshack.us/img154/8804/p9160044va4.jpg
http://img79.imageshack.us/img79/8549/p9160045yw5.jpg
This AR crossover is really nice sounding, better then the previous crossovers I used.
Best regards,
Walt
Old 17th September 2006, 03:18 AM   #190
cheesehead's Avatar
Unhappy But the Vifa drivers are going away!
The P13 project looks great, and I was thinking of, as Dave said, putting it in the queue... but the P13 driver is being discontinued. Can we start Reference Project #2?
Possibilities:
The Seas 27TDFC tweeter seems to have a following and appears to be easy to cross over...
And keeping things in the spirit of the P13, any of the Seas CA12, CA15, or CA18 could work. And Madisound sells shielding cups.
Hmmm... the CA12RCY, vented f3 at 75Hz in a 2L enclosure... where was that thread about a BO$E slayer?
cheesehead
Copyright 1999-2017 diyAudio
