Old 7th January 2004, 09:34 PM   #1
PatR is offline PatR  United States
Default CSS Super Elf or PartsExpress BR-1
Topic says it all. First speaker build project application music listening rock celtic classical. Small room appox 12 by 12.
WHich would better suit my needs? DO both need a Sub? Would rather stay away from a sub if possible, is there another good starter set ? Would like to stay at appoximately this price range no more than $200.
Thanks in advance hope to someday beable to foolw some of the discussions here grins
Old 8th January 2004, 05:07 PM   #2
RAW is offline RAW  Canada
The Super Elf was designed for HT and use with a sub.
It will take music vocals very very well.
When I first designed them for CSS Bob was a little superprized to hear what he was getting out of 2 3" speakers.But the 871 goes out to 23 K so it should should a little impressive.
Anyway against the BR1 kit the BR1 will give you a finished cabinet with a larger driver as well.
Not that I am dissing the SE but if you want the larger driver got to the BR1.
I have listened to them and find the upper end detail not as rich and teailed as the SE is.As well the cabinet size can come into play for some people.
Both will need a sub hands down.
Pick is yours
Al
Old 8th January 2004, 07:23 PM   #3
Thanks so much for the reply.
Which sub is recomended for use with SE?
Old 8th January 2004, 08:07 PM   #4
For the money at this time for Small HT use .
The TB ported in a 1cft cabinet with the Solen Sub 100 amp.
More than enough for a budget HT.
If you want more than the TB go to the Shiva in a 17" cabinet using the AVA250 AMP.
But for a small room the TB ported will give a vry very good bottom end off the SE.
With out a lot out of the pocket.
Al
RAW ACOUSTICS
Old 8th January 2004, 09:18 PM   #5
IMO the BR-1 would not need a subwoofer for music
in a 12' x 12' (unfortunate shape) small room.
Don't know much about the ELF as documentation is poor.
With the BR-1 you'll only a sub if your a bass freak.
Just get some decent stands for the BR-1's.
(and damp the cabinets with vinyl floor tiles)
sreten.
Old 9th January 2004, 12:54 AM   #6
ok why is a square room and unfortunate shape?
I think I read here 5 layers of viny tiles , are the cabinets too thin in the standard Br-1?
Thanks again for the help
Old 9th January 2004, 01:04 PM   #7
A) Its difficult to get smooth extended bass in a square
room as two of the 3 room dimensions are identical.
The 12ft room mode frequency is 47Hz. It will be difficult to
extend bass below this frequency without boom at this
frequency. You may need to experiment with port damping.
Standmounting clear of walls / corners will help smooth bass.
The 2nd room modes will at 94Hz. The room will be difficult
to drive inbetween, specifically around 66Hz. Ideally the
room height mode should be at this frequency to help, so
if room height is between 8 and 9 feet this will help a lot.
B) the BR-1 cabinets are 12mm MDF which is normal commercial
practice for that size of cabinet. I feel adding damping is an easy
and worthwhile option. With thicker walls it becomes difficult to
add enough damping to be worthwhile.
Use the cheapest and thinnest floor tiles you can find,
the more layers there are the better it is for damping.
Cover the main central area of the side and back panels with
a pad made from ~ 5 layers of thin tiles total thickness ~ 4mm.
This will improve the midrange performance.
sreten.
Old 9th January 2004, 01:46 PM   #8
An alternative might be a compact floorstander with an
overdamped reflex alignment or a T/L tuned to near 33Hz
in an attempt to drive the room below resonance.
This or something similar could possibly work well :
http://www.partsexpress.com/projects...l/default.html
sreten.
Old 9th January 2004, 08:43 PM   #9
P.S. in the above T/L design the angled sections are too long, they should be shortened somewhat.
sreten.
Old 9th January 2004, 09:52 PM   #10
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Hi Raw,
which TB driver do you you recommend?
thanks
Partsexpress problem Moondog55 Multi-Way 10 20th July 2009 12:38 AM
new cabinets at partsexpress i4gotmyid Multi-Way 11 20th October 2007 09:10 PM
Anyone used these? Partsexpress today trunkmonkey Multi-Way 3 24th July 2006 02:43 PM
bad partsexpress amp? nayr2 Subwoofers 3 18th November 2005 09:09 PM
partsexpress super cheap drivers Jared Multi-Way 4 12th January 2003 02:12 PM
Page generated in 0.11360 seconds (76.85% PHP - 23.15% MySQL) with 10 queries
