Old 7th January 2004, 09:32 PM   #1
Default Question of how to glue driver surround to casket...
Hope someone can give me some advice on which glue to use when glueing a rubber surround to a steel casket. I bought a pair of these audax 10inchers 89 and they have been laying in my closet since then... Well seems as if they've come unglued! It will probably be diffecult to get the voicecoil centered again as the cone is sagging somewhat. How important is this when using the driver in a subwoofer?
/Niclas
Here's a picture to illustrate my situation:
Old 7th January 2004, 09:53 PM   #2
SY's Avatar
Centering is quite important. But if the surround has only come loose in that one spot, you might be OK. Try gluing it back down with contact cement, then carefully push it through its excursion range (spacing your fingers equally around the cone for balance). See if it rubs. If not, then try it on some sine waves. If it does rub, you'll need to remove the dust cap and the surround, shim the voice coil, then reglue the surround.
With contact cement, the trick is to apply it to both surfaces, let it dry, and only then bring the surfaces together.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 7th January 2004, 10:04 PM   #3
Thanks SY
I'm afraid that the whole surround is loose. What do you mean by "shim the voice coil"?
/Niclas
Old 7th January 2004, 10:06 PM   #4
diyAudio Retiree
Default Kind of creepy if you ask me.
"Hope someone can give me some advice on which glue to use when glueing a rubber surround to a steel casket."
Why would you want to make a speaker enclosure out of a casket.............
Old 7th January 2004, 10:10 PM   #5
karma is offline karma  Canada
karma's Avatar
if you like them send them to a speaker shop have the spider
replaced and new surrounds. if thay have been siting on there
face the spider will be compressed it would he hard to center it
or the voice coil will bottom out.
i use rubber cemment to fix surrounds
Old 7th January 2004, 10:12 PM   #6
SY's Avatar
Default shimming
What this does is to mechanically force the coil to be centered. You take some shim stock, which is like foil of a known thickness (check with Audax on what the gap should be; shim stock is available from a variety of sources and can be plastic, brass, or steel) and insert it between the coil and magnet or pole piece. Usually, you'll use three or four pieces spaced around the coil so that the coil is forced to center. Then the surround is glued in place.
After it's dry, remove the shims and glue on a replacement dust cap. If Audax doesn't give you a gap size, then you can trial and error it by using thin shim stock and stacking it; IOW, if three or four stacks of two pieces each still doesn't immobilize the cone, go to three pieces. And so on. Hope this is clear- this is a tough one to describe without using my hands
To find shim stock, check with companies that supply machine shops.
Old 7th January 2004, 10:16 PM   #7
karma's Avatar
ya that will work to center it. will the spider come back from siting face down?
Old 7th January 2004, 10:18 PM   #8
karma's Avatar
in the closet face up or down?
Old 8th January 2004, 02:47 AM   #9
mwmkravchenko's Avatar
Default Shim stock
PAper is the cheapest type of shim stock. Business cards playing cards thick card board normal paper. They will all work out and they are cheap and easily available. You just need a way to measure them. Buy beg borrow a micrometer and go to it. Adventures in reconing are the beginning of great things.
Mark
Mark
Old 8th January 2004, 05:27 AM   #10
The one and only
Nelson Pass's Avatar
Default Re: Kind of creepy if you ask me.
Originally posted by Fred Dieckmann
[BWhy would you want to make a speaker enclosure out of a casket............. [/B]
I'm planning on making my casket out of a Rushmore.
bose 901 driver surround repair replacement jaya000 Multi-Way 37 2nd September 2009 03:26 PM
Tear in Driver Rubber Surround slhijb Full Range 4 27th July 2007 09:00 PM
What kind of glue to repair HiVi BS3 driver MrDodo Multi-Way 0 15th September 2005 12:50 PM
What type of glue for butyl rubber surround repair? c_h_shin Multi-Way 0 19th May 2004 05:37 AM
Driver Cone and Surround Damping Paint mrfeedback Multi-Way 0 22nd July 2002 03:30 AM
Page generated in 0.10909 seconds (78.43% PHP - 21.57% MySQL) with 11 queries
