what is the disadvantage of buying a generic cross over.
ive seen many postings telling people to build it from scratch. if i find a generic one giving me the right frequencys for my drivers wouldnt that be simpler..... thank you |
#2 |
Most generic crossovers are simple low/high pass filters tuned for resistive load at "nominal" impedance. Actual impedance of a speaker varies quite considerably with frequency, and as a result these simple crossovers may give quite a horrible overall response. For a cheap and simple speaker project, fine, but for a serious speaker project proper simulation for the particular drivers is a must.
Cheers |
#3 |
sorry i am a newbie at this, ive done a lot of research but im still missing little details.
when you say "nominal impedance" do you mean the 8ohms rating. So when i am using software to get the values of the caps and coils for the XO i should not use the 8 ohms rating, thank you for your reply. |
#4 | |
Its all fairly involved, but can make as much difference as a correctly tuned cabinet. Cheers |
#5 |
just another
Just to add to what Centauri said, the impedance of a speaker tends to rise as the frequency response rises. The crossover is designed with a particular impedance in mind (eg 8 ohms) doesn't give the same level of cut at higher or lower impedances.
The impedance compensation network basically "flattens" the impeadance curve of the speaker so that the crossover sees a constant impeadance. So (and now I'm speculating) I guess if you added a zobel to a stock crossover then maybe (assuming the crossover freq was suitable, and the response curve didn't have any nasty peaks) a stock crossover would be ok. This of course assumes that they have used decent caps and coils....... Just for the record I'm only going on theory here. I personally have stock crossovers in my system with no zobel, but I have been researching, and am planning on doing my own Tony. |
#6 |
thanks a lot for clarifying that
| How to cross over | Learnincurve | Subwoofers | 7 | 30th January 2005 06:42 PM |
| A cross between A5 and A3 | Stabist | Pass Labs | 47 | 21st December 2004 05:27 AM |
| How do you cross over really low? | Nappylady | Multi-Way | 7 | 25th June 2004 08:29 PM |
| No Cross Over! | chris ma | Multi-Way | 27 | 3rd January 2003 01:53 AM |
| What do you get when you cross... | nobody special | Pass Labs | 13 | 12th October 2002 05:47 PM |
| Page generated in 0.09080 seconds (78.00% PHP - 22.00% MySQL) with 10 queries |
