vintage Sony speakers made under liscense in canada? - Page 2 - diyAudio
Old 20th April 2014, 11:38 AM   #11
system7 is offline system7  United Kingdom
system7's Avatar
Originally Posted by turk 182 View Post
would anybody have any info on these as to wattage? or detail specs on the drivers?
I doubt it. But it looks like a child of its time.
The bass will be high efficiency with a rigid surround I expect. It probably has good natural rolloff around 3kHz. It looks like lowish inductance from the small voicecoil, probably Le around 0.6mH, but I could be wrong on that. The 3" and 2" cone tweeters get 2.2uF and 1uF probably.
The bass won't take more than about 20 watts I expect. It's closed box, isn't it. And quite big at that. But I don't suppose it goes very deep with a cloth surround.
I have had a lot of fun giving this sort of speaker a proper crossover for a two way. It then sounds incredibly good. Efficient too.
Best Regards from Steve in Portsmouth, UK.
Old 20th April 2014, 11:59 AM   #12
diyAudio Member RIP
That bass/mid mounting is distinctly odd. FWIW it would probably
work better as a two way with the mid omitted than it does as
a 3 way, the x/o is too crude and has too much driver overlap.
rgds, sreten.
Old 20th April 2014, 12:20 PM   #13
when i brought these orphans out of time home from the "thrift" store the one that worked surprised me with how sensitive it was, which intrigued me.the non working one turned out to be a corroded input terminal.
so after giving them a listen for a while and liking them it didn't resolve my curiosity as to "what's in there"
the mdf boxes are kind of ratty and moisture swollen so cutting the backs off was no big deal.
so think i'll forge ahead and give them a new home just not sure what kind?
the 18.5 x 10.5 x 8.5 inch "doghouses" that they are aren't that big so upsizing their new home is probably in order along with better x-over.
Old 20th April 2014, 12:41 PM   #14
system7's Avatar
The cabinet should be pretty similar to the original I'd think. It's odd that they glued it all together with the drivers mounted on the inside. You'd want some to get some access normally for maintenance, without having to smash the box up...
These were some Sony E44 I picked up with a mere 2.2uF on the mylar dome tweeter. I guessed the woofer was well behaved since it ran full range.
I gave it the barest minimum bass crossover that satisfied phase requirement:
DIY with Kef and Celestion
I guessed the tweeter wouldn't need much attenuation since levels were right in the first place, and so it turned out, 2.2R is series/22R shunt was near enough. I have built variations on this with cone tweeters and they work well too.
Old 24th April 2014, 11:10 AM   #15
i think the smaller cut out on the bass driver was intentional cheap/crude method of changing tone and level on the bass driver.
without driver specs it will be hard to do anything other than reproduce the box.
Old 27th April 2014, 12:15 PM   #16
well i made an attempt at measuring T/S parameters i think i'm in the ballpark (my antique test gear and hasty/sloppy methodology made for large differences in results)
ss610b: Fs:69hz Qts:0.7 Vas:30.9 liters
so what would you do with a driver like this....?
i'd still like to find any sort of hint as to wattage.
Old 27th April 2014, 07:40 PM   #17
frugal-phile(tm)
planet10's Avatar
Open or infinite baffle or an aperiodic box.
Wattage is not really all that relevant or important. They likly don't needmuch and could likely be melted down fairly easily with unjudicious useof the volume control.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th April 2014, 12:20 PM   #18
don't know enough about open baffles or have the right listening space (me thinks)
with the high Vas i'd have to go big (huge) in order to stay flat down low no?(i should maybe re-do my measurements and calculations a few times)
so what's the scoop on "aperiodic"?
Old 28th April 2014, 07:13 PM   #19
frugal-phile(tm)
planet10's Avatar
Big box (at least Vas), and then make it leaky, then damp the leask for flattest impedance hump or use GM's clik test. You are trying to flatten the humpin response caused by putting the driver in a box (with a 0.7 Qts it won't be too bad, which is why just a BIG box will work too.
dave
Old 29th April 2014, 10:33 AM   #20
i was trying to convince my wife to let me convert our bedroom closet into a new home for these she told me to make boxes big enough to move into with them....
the click test is that the ol' David B Weems spdt switch with a battery and 10 ohm resistor?
so far verifying my measurements bears out that Vas
so how big to start? the original box was something like 18 x 12 x 8 with the undersized driver opening
Best place to purchace full range speakers in Canada dmongrain Full Range 28 3rd January 2017 05:49 PM
Vintage sony SS-U780 worth repair? swedishlobster Multi-Way 0 28th March 2014 06:11 PM
New Made in Canada 22mm Tweeter Series $70 a Pair CSS/XBL CSS 10 5th January 2014 02:27 AM
FS: Eight (8 units) Vintage Pioneer Radial Horn Tweeters (Made in Japan) dtm1962 Swap Meet 1 14th February 2008 11:10 PM
FS: Sony 4inch vintage alnico speakers MichaelPublic Swap Meet 2 3rd August 2007 06:29 PM
Copyright 1999-2017 diyAudio
