Jaycar JV60 speakers/boxes...
Old 18th April 2014, 11:43 PM   #1
ThyDntWntMusic is offline ThyDntWntMusic  Australia
Default Jaycar JV60 speakers/boxes...
So, I grabbed myself a set of these boxes, and the associated speaker kit...
The boxes were "cheap" because one had been dropped, and the baffle was half disconnected...
This revealed a pretty serious issue with their construction... they're barely even glued together!
So I attacked both boxes with a hammer, popped the baffles off, and then the bottoms... Ran a bead of wood glue along all joins, then reglued the bottoms and baffles...
NOW!
I get the impression that the crossovers, although reasonable, can be improved... Does anyone have a schematic of the improved crossover?
Should I just assemble the setup "as is" and see how they sound? Or is it worth leaving them apart till I upgrade the crossovers?
Old 19th April 2014, 12:35 AM   #2
aspringv is offline aspringv  Australia
Hi there - I seem to recall there's some solid info on red spade audio... um
Red Spade Audio: JV60 upgrades
...and there's more than a few threads here at diyaudio about such a mod as well.
I for one would build the speaker with one critical difference - run cabling for each driver to a set of binding posts on the back. This will allow you to tweak and change your crossover to your hearts content with ease (the crossover is external to the box), and allows you to try bi-amping with an active crossover/dsp if you start to play with things that way...
Jaycar JV60 speakers/boxes...Hide this!Advertise here!
Jaycar JV60 - Speaker Kit - 2010 Version Musiccynic Multi-Way 10 5th June 2017 03:17 AM
Old Jaycar speakers CW2108 - What to do with them konman Multi-Way 30 16th August 2016 09:51 PM
Jaycar JV60 Kit Speaker Build robywan Multi-Way 3 7th December 2010 12:05 PM
Jaycar JV60 crossover upgrade canetoad Multi-Way 18 19th October 2010 01:01 PM
Hello and query re: Jaycar JV60's plasmodium Multi-Way 2 15th November 2002 10:48 AM
