Linn Nexus LS250 - diyAudio
Old 17th April 2014, 08:04 PM   #1
Junie is offline Junie  Philippines
Default Linn Nexus LS250
Hi to all, Please can i have your opinion on the said speaker the sound is not that good to my ears. Do you guys think if i recap the crossover will be beneficial or i'm only going to waste my money. Thanks in advance for your help.
Old 18th April 2014, 01:28 PM   #2
DeonC is offline DeonC  South Africa
DeonC's Avatar
Those drivers look similar the those used in the Keilidh. Those were very nice speakers. They were very musical. If they are they the same, these would be great speakers. So for my part I would say go for it.
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Old 18th April 2014, 04:33 PM   #3
Hi DeonC, i think so i find rare article about nexus LS250 so i'm not sure. I will replace those bennic caps, do you have a preferred specific caps for this application?
Old 19th April 2014, 08:50 AM   #4
system7 is offline system7  United Kingdom
system7's Avatar
They really shouldn't have deteriorated totally.
I would note the wiring polarity to the drivers, then totally disassemble and have a look for corroded connectors and perhaps broken solder joints.
What is wrong with the sound, exactly? That can help diagnose the problem. You can put your hand over the tweeter, for instance, and listen to the bass on its own more or less.
Best Regards from Steve in Portsmouth, UK.
Old 19th April 2014, 09:14 AM   #5
I find the bass less (thin) while the tweeter is harsh. Now Im using subwoofer to have a better bass.
Old 19th April 2014, 09:21 AM   #6
system7's Avatar
Last time someone complained of that fault, he found that putting his Musical Fidelity MC4 speakers up on stands to ear height cured it.
replacement tweeters musical fideleity mc4 speakers
Old 19th April 2014, 09:44 AM   #7
:-) mine came with stand. I compared with other speaker but i noticed the linn's bass is thin. I tried different positioning but no joy.
Old 19th April 2014, 09:57 AM   #8
system7's Avatar
It looks like they are bass light. That would suggest they work best close to a wall.
Interesting speaker. It's designed to be fast in response. That usually means a small bass coil, which would explain the bass light nature.
Legend Acoustics - The Legend Story
Old 19th April 2014, 10:23 AM   #9
DeonC's Avatar
Here are some links about the Linn Nexus:
Weekend Score? Linn Nexus LS250, info appreciated - AudioKarma.org Home Audio Stereo Discussion Forums
LINN Nexus Floorstanding Speakers reviews - Audioreview.com
Linn Nexus LS250 - AudioKarma.org Home Audio Stereo Discussion Forums
Old 19th April 2014, 12:51 PM   #10
Aha i found something, previous owner replaced the tweeter with scan speak. I tried covering the tweeter with my hand i noticed that it's too much "skeeech" causing fatigued to my ears. This might be the reason it's overshadowing (don't if it's the right term) the low frequency. I had a mail correspondence with hiquphon for the correct tweeter replacement. Will post the result after.
TAS5713 Nexus Q jarrettv Class D 1 21st January 2014 06:26 PM
F/S linn LK1 pre + Linn Dirak power supply j baldam Swap Meet 0 18th January 2013 06:02 PM
Linn Kaber Keilidh Nexus Baffle Front Covers/Grille Cloth with Strap needed tiefbassuebertr Multi-Way 2 7th August 2011 12:34 PM
Ion Nexus gsm Solid State 0 30th August 2005 07:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
