Pics new 4-way Azura horn system, plus BIG bass horn - diyAudio
Old 16th April 2014, 04:00 AM   #1
Default Pics new 4-way Azura horn system, plus BIG bass horn
Having built numerous projects including Tannoy GRF, Carfrae Little Big Horn, numerous Lowthers, GOTO, Altec and Klipsch...I'm now embarking on a radical new 4 way system, featuring:
Azura 340Hz horn and JBL 2445 drivers (with large 2 inch throat)
Eminence Lab12's 12-inch subs (2), with rear facing baffles for corner loading
Large new mid-bass horn taken from Martin Sneddon's design, plus tweaked...will be 1.5m tall, with mouth of 85cm x 85cm, and geature Altec 515 15-inch woofers.
Tweeter TBA, likely Azura 1,000Hz and suitable 1-inch compression driver.
Dual MiniDSP's to run the xovers.
Holton Precision Audio six channel power amp.
The Azura 340's are sounding very nice indeed....and I'm 70% through the build of the mid bass horns. The Lab12 subs are completed, and recently painted in mid gloss white to match the horns.
The mid bass horn upright tower section will be white, while the mouth is in Birch Ply, and I will leave natural colour.
xover points are:
Subs 20-90Hz
Mid bass 90-450Hz
Azura 340 horn 450Hz to 5,000Hz
Tweeter, 5k+
A really fun project...but a lot hinges on the mid bass horn for the true magic.
Andrew
Old 16th April 2014, 04:01 AM   #2
Note - on mid bass horn drawing, it shows mouth as 85cm x 70cm...that is incorrect...it will be 85cm x 85cm.
Old 16th April 2014, 07:56 AM   #3
Man, that is some serious speaker-porn!
Old 18th April 2014, 11:43 AM   #4
Today I chamfered 6 pieces of ply to create a curved section near horn mouth.
Used fast drying glue for quick adhesion.
Old 18th April 2014, 02:46 PM   #5
Sodacose's Avatar
Subscribed!
WTF Amps || /r/diytubes/
Old 18th April 2014, 09:56 PM   #6
atilsley
I have seen some of your past builds and was impressed, however I don't see why you would build a mid bass solution that is much less efficient than your midrange horn even with using dsp.
Old 18th April 2014, 11:16 PM   #7
expert in tautology
bear's Avatar
What drivers are you using on the Azura?
Would like to see actual measurements if possible on the 340 wide open... no xover.
hottattoo, I think that is why they invented bigger amplifiers?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 18th April 2014, 11:30 PM   #8
Originally Posted by hottattoo View Post
atilsley
Thanks.
The build of the mid bass horn is mainly around the dynamics and scale such a horn delivers...plus I simply like large horns...!
Efficiency wise, not an issue. With altec 416 or 515, I'll have 100db...with small adjustment on minidsp, this will work fine with azura.
Azura is being used with JBL 2445 at the moment.
I'll submit a recording of another 340 I had with selenium one inch driver....remarkably flat for a cheap driver and relatively cheap horn.
The two inch throat 340 provides more attack...and I'm currently crossing this at a low 450hz.
Mid bass horn especially designed to cover 100hz to 500hz....which is the very critical range.
Martin Sneddon of azura has same type of horn, and puts this way ahead of his other horns, eg the big 160 model. It was his comments that made me decide to go down this fun path.
Plus, I'm a builder and creator...!
Old 19th April 2014, 12:26 AM   #9
atilsley;
You cant.t go wrong with the Altec 515. I use the 515b and found it to be the best for mid bass duty. Your system should sound great when complete !!!
Old 19th April 2014, 01:13 AM   #10
atilsley;
Thanks...I've spent a few years working it all through...and have built many systems using 604's, 416's, my own made Yuichi 290Hz horns, Tannoy GRF horns, GOTO bass horns etc.
Big Bass Horn -- I know you're gonna like this CLS Subwoofers 6 30th April 2010 10:02 PM
Pics of 3-inch Fostex in big Traxtrix horn atilsley Full Range 4 25th May 2009 05:54 PM
Pics of CNC routered Big Fun Horn atilsley Full Range 6 22nd October 2008 08:53 PM
Combination flare on front (Azura) horn limono Multi-Way 18 26th December 2007 06:26 PM
DIY Azura/Oris type horn BTW Full Range 0 12th October 2005 12:24 PM
Copyright 1999-2017 diyAudio
