Pics new 4-way Azura horn system, plus BIG bass horn
Old 19th April 2014, 02:17 AM   #11
atilsley is offline atilsley  Australia
Originally Posted by bear View Post
What drivers are you using on the Azura?
Would like to see actual measurements if possible on the 340 wide open... no xover.
hottattoo, I think that is why they invented bigger amplifiers?
Here's a recording using Selenium DT220 one-inch driver.
I'll do another recording with bigger JBL 2445's later. These are sounding very good at the moment...and I'm using cheapy horn tweeters (P-Audio) to test the upper range.
I might try and keep the system three-way....for example, the Faital Pro HF200 comp driver measures very well from 500Hz to 18,000Hz. I've used this driver before in the Bob Crites Cornscala. If I had a few more $$'s, I'd go with one of the new Be models from Radian....very good range recently introduced....but $600-$700 each.
Old 20th April 2014, 04:27 AM   #12
bear is offline bear
expert in tautology
bear's Avatar
Yes, very nice curve!
I'm surprised the Selenium did this well.
Any smoothing there?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 20th April 2014, 05:35 AM   #13
1/48th
Old 20th April 2014, 10:20 AM   #14
Filled joins with putty, added extra bracing, added wool/fibre to cavities, drilled counter sunk holes to baffles.
Old 20th April 2014, 10:32 AM   #15
Zvu is offline Zvu  Serbia
Sin Bin
Originally Posted by atilsley View Post
Here's a recording using Selenium DT220 one-inch driver...
Hi Atilsley, what is mic distance from Selenium D220ti ?
Nice build by the way
Old 20th April 2014, 01:33 PM   #16
Devilsdance7775 is offline Devilsdance7775  Australia
Gee, so nice to see sound enthusiast living in Sydney
Old 20th April 2014, 08:08 PM   #17
Lynn Olson is offline Lynn Olson  United States
Lynn Olson's Avatar
Nice build! Also good to see a bass horn optimized for the Altec/GPA 515.
Old 21st April 2014, 03:55 AM   #18
Thanks guys....Lynn, priveleged you'd say so...as I've watched/read many of your projects.
I'm a builder/enthusiast...and love anything big.
I've built Carfrae, Big Fun Lowther, GOTO bass horns, Tannoys, Cornscala, ALtec 620, Altec Stonehenge with 604...just love playing around...and the sound of a big cab is great.
With this bass horn, it's certainly a mroe ambitious project....
I'll keep you posted.
Old 21st April 2014, 06:26 AM   #19
1.2m
Old 22nd April 2014, 12:53 AM   #20
Throat section now angles back a little with use of putty.
Pics new 4-way Azura horn system, plus BIG bass hornHide this!Advertise here!
Big Bass Horn -- I know you're gonna like this CLS Subwoofers 6 30th April 2010 11:02 PM
Pics of 3-inch Fostex in big Traxtrix horn atilsley Full Range 4 25th May 2009 06:54 PM
Pics of CNC routered Big Fun Horn atilsley Full Range 6 22nd October 2008 09:53 PM
Combination flare on front (Azura) horn limono Multi-Way 18 26th December 2007 07:26 PM
DIY Azura/Oris type horn BTW Full Range 0 12th October 2005 01:24 PM
Copyright ©1999-2017 diyAudio
