Hello,
I recently got some Foster Pro 15" woofers and would like to use them for a garage headbanger system. I don't have the exact specs on the woofer, but I figured I'd play it safe by putting it into a sealed enclosure, roughly 10 sq ft. I have a 2-way crossover handy which crosses at 2,600kh.
So, if you could choose one driver to cover 2,600+ what would be a good match for this pro woofer? I have a pair of Hivi B3N, but I think they would get buried by the more sensitive/powerful woofers. I could possibly go 3-way but would like to stick with 2-way. Any ideas?
The B3N would be hopelessly lost in such a setup.
if your going to guess at a box volume at 10 cuft,
which could be very wrong, and very probably is,
a better guess is 4 cuft vented, tuned to 40Hz.
(Or 33Hz for very low bass heavy stuff.)
Tweeter on the cheap is a 4"x10" like :
Pyle PH391 4" x 10" Horn Tweeter | 292-2624
Though I'd also add an L-pad.
I have no idea how well your crossover will work.
rgds, sreten.
rgds, sreten.
Yeah, kinda thought so.
The reason I'm guessing on enclosure size is because somebody scratched off the info on back. So I have no model number. But based on it's weight, frame and magnet, I'd guess it's high sensitivity and high QMS.
Well, I hooked up the Fosters inside the cabinets and ran them full range. They sounded really good. So I decided to add a Goldwood GT-1005 piezzo tweeter that is tamed by an in-line resistor. It was an inexpensive solution plus I can always upgrade later to a better tweeter and the 2-way crossover if I want.
The cabinets wound up being 6 cubic feet vented.
- 2-Way garage rocker. Help me pick mid/tweeter driver please
