I need to fuse a loudspeaker to prevent overpowering it. Can anyone help me relate the correct fuse current and voltage value to the loudspeaker watt value?
#2 |
This should give a workable minimum value for a fast-blow fuse:
Fuse (amps) = 1.414 X sqrt (Power rms / Impedance) A good trick for protecting a speaker from over-cooking is to connect it in series with a filament bulb. |
#3 |
Fuses don't always protect well. You don't say if you are protecting a single driver (what size) or a whole system.
Best is to start with a low current rating (voltage doesn't matter as long as it is more than your amp can put out) and increase it a bit if it blows too often. I have a 250Watt, 4 ohm speaker that came with a 2 amp slow-blow fuse on the input. 250 watts into 4 ohms is sqrt(250/4)=7.9 amps. I have blown a tweeter before the fuse blew.... Also look at polyswitches and other types of protection devices. I think Parts Express sells something like this. http://www.partsexpress.com/webpage....ctGroup_ID=568 http://www.partsexpress.com/webpage....ctGroup_ID=237
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
Thanks for the help!
| Fuse housing melting but fuse not blowing, ppi amp | rawadia | Car Audio | 21 | 2nd August 2008 10:39 AM |
| Power Supply Rating / Fuse calculation / Understanding ? | artquake | Power Supplies | 23 | 24th June 2008 09:41 AM |
| amp rating for fuse and fuse holder? | riotubes | Parts | 5 | 27th August 2006 03:10 AM |
| Mystery Amp Rating on Fuse | DreadPirate | Solid State | 5 | 24th April 2006 01:10 PM |
| Help - fuse rating (USA style) | TNT | Parts | 2 | 7th March 2004 03:04 PM |
| Page generated in 0.10222 seconds (75.34% PHP - 24.66% MySQL) with 10 queries |
