Recommendation of 8-Inch Woofer + Real Tweeter
Old 13th April 2014, 04:50 PM   #21
krafty is offline krafty  Brazil
Parts Express doesn't ship to Brazil. What a shame, I guess I will have to look for those Daytons or a kit elsewhere.
Old 14th April 2014, 12:59 AM   #22
murphythecat8 is offline murphythecat8  Canada
look at meniscus kits!
Old 14th April 2014, 01:13 AM   #23
Thanks murphythecat.... Looks promising.
Old 14th April 2014, 01:20 AM   #24
Originally Posted by wolf_teeth View Post
When you can get an extra octave more extension going vented, I would advise not shrinking your box smaller. Using an 8" to 66Hz as the lowest seems like a waste to me.
Later,
Wolf
I would like some "analogy" on how the techs of what you say is, so it would be easier to understand and see this.
I thought of going vented with my current drivers, since it matches their datasheet.
Old 14th April 2014, 05:03 AM   #25
Ok, so I have the exact size of my current box.
Not having to do anything to it, apart from adding port or re-lacquering/painting would be the ideal thing for this project.
The measurements from within, discounting the ply are: (I will do it in centimeters because I can't interpret well the inch system without major maths in here ).
Height = 50cm
Length = 29,9cm
Depth = 22cm
That gives a 32,89 Liters box. Minus 1 Liter of driver displacement: 31,89. This is REAL CLOSE to the Dayton specs for a vented box. I don't know if I could get away with it. Could I possibly do?
Another thought would be to get the front ply and move inwards about 5 cm (down to 25 L), which would not be enough for a sealed box, with this Dayton woofer.
The Dayton woofer is really on a budget in Canada, being HALF of the american price. Someone needs to fill me in why this is like that (Health care system kinda analogy related here? )
So I could buy these two Dayton, two Dayton dome tweeters (RC28F-8) and design a crossover after the parts arrive home... for sure I'd get the air core inductors with the purchase because the guy I know only work with 17 AWG and charges an eyeball for it.
Old 14th April 2014, 12:28 PM   #26
Inductor is offline Inductor  Portugal
Inductor's Avatar
Perfect. It just needs a long port (50cm) for the 30L in the reflex enclosure that can be adjusted later. Nice driver on paper.
2-way, using Dayton Audio RS225-8 woofer and RS28F tweeter:
RS duet by Paul Kittinger
Old 14th April 2014, 12:45 PM   #27
system7 is online now system7  United Kingdom
system7's Avatar
Sorry to be a nag, but that vent doesn't sound remotely right to me. I'd be looking at 50-60mm diameter and about 10 cm. long. Adjustable tubes are quite useful with this sort of thing. You glue or duck tape them solid when they are about right.
Best Regards from Steve in Portsmouth, UK.
Old 14th April 2014, 01:50 PM   #28
SS4927 is offline SS4927  Canada
SS4927's Avatar
I will use a seas prestige 8 inch woofer. With a classic 6.5 vifa thats known to be very smooth in the mid range. I have some very good sounding full sized sealed boxes that accept 8s I will first try the seas in. On paper they look like they will work in a sealed speaker. If they dont line up I might be able to use them as another reference to gauge new dimensions.
Old 14th April 2014, 05:21 PM   #29
dumptruck is offline dumptruck  United States
Exchange rates are equivalent and the prices look the same from here. Is it possible the USA price has duties included or something? Not sure what you're looking at.
Old 14th April 2014, 05:48 PM   #30
Inductor's Avatar
You are a nag...
I was mentioning the port so that the OP is aware that will reduce internal volume.
A speaker that is larger (volume) will have a shorter port. In this case a smaller than optimal 30 L the port (~2/3 L) will play a significant roll in the alignment of the speaker and it's internal dimensions. It's logical, if you reduce the diameter of the port you will end with a shorter port and higher air speed for the same RMS power.
If you guys make mention of a port (size/dimensions) please make sure to post the size (volume) of the enclosure (and diameter/length of the port or tunning frequency) so that we always have a small idea of the alignment that is being talked about. The port of the speaker that is posted in my link is for a big volume floorstander speaker, so the alignment makes a big difference to the one of the OP's, with it's 5" port.
Recommendation of 8-Inch Woofer + Real TweeterHide this!Advertise here!
Real power pentode recommendation CijTele52 Tubes / Valves 15 17th May 2013 01:36 AM
Recommendation of 15 inch pro woofer for existing 3 cf box avincenty Multi-Way 19 22nd August 2012 04:38 AM
WANTED: 6-7 inch pro mid/woofer or some small box woofer Jimmy154 Swap Meet 10 18th August 2012 12:01 PM
3 to 4 inch full range recommendation gooki Full Range 8 22nd October 2010 04:46 AM
recommendation needed - is the real? aeroman1003 Everything Else 5 4th January 2008 11:35 PM
