Woofer What To Do? - diyAudio
Old 29th March 2014, 02:56 PM   #1
Default Woofer What To Do?
I have a conundrum. after years of living in an apartment with a growing Hi-Fi and a limit on volume I have finally got myself a detached house to let my Hi-Fi sing. since my amp upgrades grew to increase sound quality my speakers never grew to accommodate volume due to apartment life. it didn't take long before I blew my humble B&W DM601s2's. The woofer has gone in one channel. looking around on line I found a few options to replace the woofer, I left some bids on and I got a new replacement driver. I forgot about the other bids and I now have another pair of DM601 S2 speakers (minus the tweeters). my thinking is....can I hook up the second set of speakers in parallel with the first set? are there any merits to this? will this reduce the load on each individual woofer? will I get a better sound quality? or will i have half the volume in the woofers with the same sound quality, while the hi freq has a normal load? I could amplify each driver, 50w to hi, 100w to mid1, 100w to mid2. Would a diy xover let me take better advantage of this situation? or should I just keep the volume low and save up and buy a proper set of screamers? Ultimately i Know i need new speakers, this will happen but the engineer in me wants to see if i can put the collection of speaker parts i now have to better use before i buy new ones.
current xover cut off is 4k, speaker range is 60-20k.
I now have:
x2 DM601 S2 (full working order, cabinet, xover, all drivers)
x2 DM601 S2 (tweeters removed, only cabinet, xover + woofers)
x1 pre amp (musical fidelity xp100)
x2 dual mono power amps, effectively 4 amps (musical fidelity xas100, 100w p/c each)
x2 power amps (musical fidelity xa50 mono amps, 50w p/c each)- not in use but optional
I am no stranger to a soldering iron and hoped a custom solution is available.
what to do? all comments/advice/suggestions welcome.
Old 29th March 2014, 10:46 PM   #2
Inductor's Avatar
You buy new tweeters or
You use the midwoofers you have available.
2nd Pair:
Take out the midwoofers.
Trash or sell the enclosure and crossovers.
Make a new enclosure about double or triple the (B&W DM601 S2) previous volume (net).
Use them as 2 subwoofers.
Go to a 6 db Crossover Table and match impedance so you can pick up a new coil@200/300Hz.
Buy new coils with very low DCR for your new subwoofers.
Connect them to the available amp (?) "x2 power amps (musical fidelity xa50 mono amps)- not in use but optional".
You presented yourself with a new pair of B&W subs.
Bowers & Wilkins DB1 subwoofer | Stereophile.com
B&W Acoustitune
http://www.bwgroupsupport.com/downlo...20Brochure.pdf
Old 30th March 2014, 12:24 AM   #3
2nd Pair:
B&W Acoustitune
Inductor, thanks for the response. I like it a lot.
some questions (sorry!):
the speaker is rated at 8ohms, does this mean the driver, without the tweeter, is rated lower? or calculate at 8ohm.
do i simply add a 4.7mh coil (260hz) to the positive supply to the woofer? to create a 260hz cut off?
what voltage should this be rated to?
is 0.26 DCR acceptable?
the cabinet you mentioned for the subs, would this be an enclosed design?
would i be better using the xa50 (50w) for the tweeters, one of the power amps (100w) for the mid and the second power amp (100w) for the subs?
thanks,
Kevin.
Old 30th March 2014, 01:11 AM   #4
diyAudio Member RIP
I don't see the point of the added "subwoofers" if the
original speakers are well balanced, you'll just screw up.
I can't make any sense of Inductors advice, it is very wrong.
rgds, sreten.
Old 30th March 2014, 09:16 PM   #5
The possibility that comes to mind with me is connecting two woofers in-series, per channel. The sensitivity of two woofers in-series is the same as that of a single woofer, so relative sensitivity of the woofer and tweeter wouldn't be altered. The two woofers in-series would make it less likely that you will blow a woofer again, as voltage is equally divided between them.
If the existing low-pass filters of the crossover networks are conventional 2nd order, you would make a new low-pass filter (adjusting for the doubling of impedance) by connecting the 2 existing inductors and capacitors of the low-pass filters for the woofer in-series.
cT
Old 31st March 2014, 08:33 AM   #6
Inductor's Avatar
It's a first order 0.95mH inductor. If using the two woofers in series, as above post, you need to double the coil to a 1.90 mH (meaning that you can also use the second coil from the extra speaker in series, instead of buying new).
cT
Old 31st March 2014, 09:06 AM   #7
cT
Hi CT, thanks for the suggestion.
This is what I had in mind but do not have the experience to know how it would act or how to implement.
my thinking is two woofers move more air than 1, there must be a way to implement them together, i have no shortage of amplification. The drivers are identical and the cabinets they are currently housed in were designed for these drivers. distancing and phase is something i was unsure about, but this can be tested in practice with listening and then modifications.
i have (hopefully) attached a picture of the B&W xover circuit. It appears to be a 1st order circuit for the low frequency (x1 1.4mh) and 2nd order on the hi frequency (nonsense?). How should i go about implementing the second woofer connected in series. I have attached a picture of how i interpreted your post, am i on the right track? all i am looking for now is a suitable circuit for the in series additional driver.
many thanks,
Old 31st March 2014, 09:10 AM   #8
lexer98 is offline lexer98  Argentina
lexer98's Avatar
You have a TV in the room ?
Maybe can stick DM601 woofers in a new enclosure (smaller) and used as back channel, making a 4.0 .... good for movies even music !
Sorry for my horrible English
Old 31st March 2014, 09:31 AM   #9
hi lexer, thanks for the suggestion. Its a good idea, i had considered this but my AV room does not allow for a speaker behind the sofa. I am really interested in finding a way to to add the extra woofers to my 2 channel hi-fi setup in a feasible way.
cheers
Old 31st March 2014, 10:16 AM   #10
Hi Inductor,
Just spotted your post after i replied to CT, this answers most of my questions. So using the existing 1st order LF xover is fine, and using it in series will double the inductance to suit the effect of the driver in series?
If the wiring shown in the previous attachment is correct I will wire these up in the existing enclosures and see how it sounds (still to arrive).
to be clear,
the load will be the same on the amp? I will be driving both of these from a single mono amp.
driver life should be extended as less power is going to each individual driver.
As the sensitivity is the same the amplitude will be the same and not conflict with the tweeter volume balance.
wiring in series will not cause the second driver to be out of phase?
negatives:?:
coherency in image?
positioning?
phase issues?
thanks again.
rebuilding 12"woofer system. which woofer ?? Jvsantosmd Multi-Way 13 10th April 2014 04:25 PM
WANTED: 6-7 inch pro mid/woofer or some small box woofer Jimmy154 Swap Meet 10 18th August 2012 01:01 PM
Woofer-Fullrange-Woofer vs Tweeter-Midrange-Woofer fakeout Multi-Way 5 11th August 2012 07:17 PM
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 03:00 PM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 02:30 AM
Copyright 1999-2017 diyAudio
