Never done anything like this before so please bear with me!!! I'm toying with the idea of building a pair of 3 way speakers (I'm assuming this is the way to go). I'd like a nice bottom end (ha ha) because I mainly listen to very bassy reggae. As this is my first project I'd like this to be as cheap and easy as possible. Anyone got any suitable plans? I intend to buy the drivers from my local Maplin store (UK) and I have a decent supply of MDF. I'd prefer 8" bass drivers as this would be more suited to my budget. Any tips or help would be fantastic! |
#2 |
Check out Peerless for very nice price/quality ratio.
#3 |
I recommend winISD to simulate the low end response of your box if its important to you.
#4 |
IMO a 2 way or 2.5 way with 8"ers is a good choice for a mainly rock and pop speaker. A 3-way gets MUCH more tricky than a 2 way.
/Peter |
#5 |
Isn't there a certain type of horn cab thats meant to work really well with reggae?
Pro-audio guys please chip in Rob |
#6 |
I know eminence recommend some of their drivers to work well with horn enclosures and reggae, how believeable this is Im not sure.
#7 |
Maplins isn't the only place to look for drivers. Try these aswell.:
http://www.falcon-acoustics.co.uk/ http://www.wilmslow-audio.co.uk/ http://www.bkelec.com/ Whats your budget btw? I'm sure I've read several times about a certain horn shape for reggae... Cheers Rob |
#8 |
The crossover will be the heart of your system
You will do well to select some design that has the crossover already worked out and tweaked. Regards Ken L
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day |
#9 |
Check out the plans at speakerbuilder.net
The veritas or Lyra will move some booty! |
#10 |
Thanks for the inspiration so far everyone!
The veritas or Lyra sound like a good way to start from what I've read, just having trouble finding Dayton drivers in the UK. Anyone know of a stockist? If not are there any equivelents by other companys which are readily available in the UK? |
| New TT owner needing advice on skipping, etc | knobtwiddler | Analogue Source | 2 | 4th May 2008 12:30 AM |
| Needing advice for Open Baffle Tannoy | Sylver300B | Multi-Way | 17 | 20th November 2007 04:54 PM |
| Thinking of starting a new project, needing some advice | Jacobus | Full Range | 3 | 1st February 2006 09:28 PM |
| Newbie Needing Project Design Advice | cwoodall | Everything Else | 1 | 23rd August 2005 04:27 AM |
| newbie needing some advice | TheDarkside | Parts | 4 | 13th November 2004 07:51 AM |
| Page generated in 0.10667 seconds (79.60% PHP - 20.40% MySQL) with 10 queries |
