Old 4th January 2004, 04:06 AM   #1
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Default chocolate box cardboard coil formers :)
Okay... Probably everyone who reads this is going to think I'm completely nuts.
A friend gave me a pair of Rockwood Detanator 15" subwoofers.
They were being used at a gig when the coils overheated, shorted the amp, jumped the gap, and were toasted.
(I am also repairing the amp that got fried.)
So anyway, I decided that I'm going to try taking these speakers apart. I got the cone removed and cut the old coil former off.(It is a crumpled accordian type )
I thought, maybe I can make my own former and use what was left of the original coil (9/10ths of it was there.)
I ended up cutting a piece of cardboard from a chocolate box and forming it into a circle. I then glued the cardboard to the remaining coil and formed it into a nice round circle.
Right now, I've got the new former in the cone and the glue is drying.
Next I have to shim it into place, clamp everything down, and see what happends!
Any thoughts?
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 4th January 2004, 05:23 AM   #2
JOE DIRT®'s Avatar
I think it will work...just remember your parameters will be different for the driver
Old 4th January 2004, 05:23 AM   #3
saletel is offline saletel  United States
Default Re: chocolate box cardboard coil formers :)
Originally posted by Duo
Any thoughts?
Good luck
Old 4th January 2004, 06:15 AM   #4
Duo's Avatar
Well, it worked but I put the coil way too far back, out of the proper linear flux. I tried to move it forward but I'll never get the paper straight again cause it's stuck in the cone and I can't line up the coil on it.
For some reason, also, the coil is now 1.3 ohms, so it's obviousely shorting out in places. I think I'll just get re-cone kits for these baskets.
Old 4th January 2004, 08:05 PM   #5
Bull is offline Bull  United Kingdom
Lightbulb reply
Remember to use thick[28 0r 24 gauge] ennamled copper wire for the voice coil as it's a high power 15 inch.
And use some aluminium foil--kitchen foil is perfect 'as it can stand high temperatures in the oven'--and glue this around the cardboard tube[vc former].
And to make the voice coil wires stay in place and tightly packed together use some Epoxy resin[the grey stuff which looks like putty and dries hard used normally for sealing pipes].
So use a very small amout of this lightly spread on the former to hold the voice coil wire in place; wind the voice coil whilst putty is still wet.
like peanut butter with chocolate d to the g Pass Labs 9 29th May 2008 03:10 AM
your favorite chocolate vasyachkin The Lounge 22 13th March 2008 09:12 PM
Copper Voice Coil Formers! BarakaBloke Multi-Way 4 4th February 2008 03:54 AM
Voice Coil Formers... Kapton vs Nomex vs Aluminum vs GF/TIL OlogyAudio Multi-Way 3 1st June 2007 03:27 AM
Voice coil and formers[bobbins] Bull Multi-Way 1 21st November 2002 12:26 AM
Page generated in 0.07784 seconds (85.30% PHP - 14.70% MySQL) with 10 queries
