How to design a waveguide for bass speaker? - diyAudio
Old 13th March 2014, 12:25 PM   #1
Tyimo is offline Tyimo  Hungary
Default How to design a waveguide for bass speaker?
Hi!
Could somebody tell me?
Greets:
Tyimo
Old 13th March 2014, 04:33 PM   #2
Because of the long wavelengths of bass (40 Hz around 28 feet, 8.7 meters long) a bass waveguide would need to be huge.
More practical are cardioid or end fire arrays, but they don't work well in acoustically small rooms, that is rooms with dimensions much shorter than the wavelengths to be guided.
Old 13th March 2014, 04:33 PM   #3
tvrgeek is offline tvrgeek  United States
First, go buy a few acres.
OK, An old issue of Speaker Builder had quite a bit on bass horns. Full or folded at various times. You might look at Klienhorn for understanding bass and horns. There are several programs out there that will do the simulation. The throat and back loading are what I understand to be the biggest problem, besides pure size.
Are you looking to do a PA speaker? Physical dimensions pretty much limit them in home use. Can you say what this project is trying to achieve?
Old 13th March 2014, 07:43 PM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
depends on what you expect of it ?
in my book a waveguide on a bass is more like a midbass/low midrange helper
and it might help to phase allign a woofer with mid/tweeter horn
sometimes we know very little, and sometimes we know too much
Old 14th March 2014, 03:07 AM   #5
Inductor's Avatar
Originally Posted by Tyimo View Post
Hi!
Greets:
Tyimo
Great question.
I did my first horn for a 12" H/H (UK) PA driver, in the 80's without software or any knowledge and it worked (call it prediction), and it's very operational after all this years.
I guess you have to start somewhere:
1. You are not Tom Danley
2. You need a driver
3. You have about S space for the mouth surface of the horn and X length for the horn flare, available ().
Horn loudspeaker - Wikipedia, the free encyclopedia
Horn / Waveguide Contour Comparisons
Old 14th March 2014, 05:49 AM   #6
Hi!
Thanks for the responses!
I know how horns are working. I built some already.
in my book a waveguide on a bass is more like a midbass/low midrange helper and it might help to phase allign a woofer with mid/tweeter horn
Yes, I also think about waveguide as a helper and not a real horn. So, I think the classical horn calculation and theories are not 100% compatible.
Somewhere I read the the waveguide could be smaller, shorter than a normal horn. It is therefore not as efficient as a true horn but in return you'll have a bass free of colourations and a lot less room boundairy problems. It can help to the soundwaves to easily detach from the loudspeaker and fill the room with sound.
So my questions:
- Is a waveguide equal to a horn???
- if they are not equal:How to calculate the waveguide's throat, mouth, lenght and flare?
- How much efficient compared to a real horn?
greets:
Tyimo
Old 14th March 2014, 07:30 AM   #7
Top Shelf's Avatar
Hornresponse should easily calculate your waveguide. Are you familiar with the program.
JEREMY M_________________________________
I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ?
Old 15th March 2014, 06:45 AM   #8
Hi!
Yes, but how to begin with waveguide? See my questions!
greets:
Tyimo
Old 15th March 2014, 09:53 AM   #9
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Hornresp for Dum... hmm... Everyone - Home Theater Forum and Systems - HomeTheaterShack.com
Hornresp
AES Associate Member / My DIY speaker history: -74 Philips 3-way, -82 Hifi 85B, -07 Zaph L18, XLS10+PR/Hypex, -08 CSS125FR, -08 Hifitalo AW-7, -08 TangBand FR, -09 MarkK ER18DXT, -13 PPSL470, -13 AINOgradient
Old 15th March 2014, 10:13 AM   #10
A waveguide on a bass speaker will not affect the bass
unless its huge. Your just manipulating midrange and
there is is not a lot to be gained compared to the size
penalty of the front baffle required fpr a waveguide.
Waveguides work on tweeters because they
end up about the same size as the lower units.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Design of bass-reflex speaker danielgonzc Multi-Way 9 30th January 2013 05:52 PM
Portable class D Bass Guitar amp/speaker design SEclassA Instruments and Amps 68 2nd April 2011 10:24 AM
Filter Design to Boost Bass for Full-Range Speaker poynton Solid State 7 23rd January 2007 02:51 PM
4 Sale: Speaker Design software & 4 mid-bass drivers Eton Swap Meet 0 20th December 2003 06:35 PM
bass speaker design help dbaudio Multi-Way 0 12th September 2003 12:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
