Bass response in small boombox - diyAudio
Old 9th March 2014, 08:36 PM   #1
PsychoM is offline PsychoM  Belgium
Default Bass response in small boombox
I'm new to making DIY speakers. This is the first speaker I designed and it's very cheap, so please don't be harsh
I recently built a small boombox from an old set of pc speakers. I used the original amp.
I kept the same volume as the sub (+-9 liters) and about the same tuning frequency (60 Hz or something) but I'm having trouble with the bass response.
The woofer is shaking around violently, but it's not very effective. The original speakers had way more bass. I think the bass is canceling somewhere... ? Or maybe I need make an internal enclosure for the mid/high speakers?
Can somebody see what's wrong with the basic setup (see pictures)?
All advice/hints are welcome
Old 9th March 2014, 11:07 PM   #2
DavidL is offline DavidL  United States
Banned
First of all you need to have the "sub" driver in it's own enclosure separate from the two full range drivers. The full range driver cones are acting like passive radiators and screwing up the bass. Also in turn, the bass driver is modulating the full range drivers making them sound horrible in all probability.
Old 9th March 2014, 11:48 PM   #3
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
In addition to the sub needing its own enclosure, each of your drives do too.
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Bjorn's PS95 TABAQs
Old 10th March 2014, 12:05 AM   #4
chris661's Avatar
After you've done those mods, make sure everything's air-tight. You can test by playing a few low-frequency tones: if you hear a whistle, you have a leak, which will cancel some of the bass.
Chris
Old 10th March 2014, 01:58 PM   #5
Thanks, I was already guessing that was the problem.
I'm going to put both mid/high-drivers in their own seperate enclosure, that means I don't have to build another enclosure for the woofer right?
Also, everything is practically airtight, but I'm going to fill the inner edges with silicone paste to be sure.
Old 10th March 2014, 10:55 PM   #6
Banned
Yes sealing off the mids/highs means not building a separate box for the woofer as long as the boxes for those don't reduce the bass enclosure too much. I'd try it like you mentioned and go from there. Using silicone to seal a box works VERY well, so well in fact that you may find trying to open the box later almost impossible without breaking it.
Old 10th March 2014, 11:45 PM   #7
diyAudio Member RIP
Boxes than need anything in the corners are just
very poorly glued together, that is a problem.
rgds, sreten.
Old 11th March 2014, 04:18 AM   #8
picowallspeaker's Avatar
Mike
ALso the electronics should not be enclosed in the same box.
Mods! I like it ! Putting cheap at its best.
Ohhh...we were talking about a boombox-ghettoblaster-old portable cassette/receiver
Amp to small boombox? g0liat Class D 14 23rd July 2013 06:16 AM
Another (small) Boombox Build lost eden Class D 30 4th January 2012 10:14 AM
How to get good bass response from a Boombox?? ThunderMonkey Full Range 6 20th December 2011 03:37 AM
Need a little help on small festival boombox ThokN Construction Tips 22 6th May 2011 12:47 AM
looking for a small 2" or 3" driver with poor bass response space-cake Full Range 3 27th December 2007 01:16 AM
Copyright 1999-2017 diyAudio
