Old 4th January 2004, 02:27 PM   #21
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
KYW, I have looked for suitable woofers for di-pole use from:
Maplin
Farnell
CP
Prospeaker Audio Part
Allan Gordon
BK Electrics
DAS Audio
Design Audio Shop
Electrovision
IPL
Ross
SCV
P.Audio
Wilmslow
I have also looked a car audio drivers from Alpine, Pioneer, JBL, Kenwood, Sony and US Blaster.
I have found the odd driver with suitable parameters but these have either been far too expensive or I have not yet got a price back for them, eg TM series from P.Audio. I am also awaiting T/S parameters from some of the car audio driver manufacturers.
So where else do you suggest looking? I am not looking for something for nothing but as I need four of them, I must limit the price each to around the 50UKP range.
One close match that I have found is the Alpine SWE1241, a 12 inch woofer with the following T/S parameters
Coil Height (Hvc) : 33.4mm
Cone Area (Sd) : 490.87 sq. cm
D.C.Coil Resistance (Re) : 3.6 ohm
Electrical Q (Qes) : 0.70
Equivalent Suspension Stiffness (Vas) : 61 liters(2.3cu.ft.)
Free Air Resonance (Fs) : 31Hz
Frequency Response : 26Hz - 1kHz
Gap Height (Hag) : 10mm
Impedance (Nominal) : 4 ohm
Inductance (Le) : 2.78mH at 1kHz (0.86mH at 20kHz)
Linear Excursion (X linear) : 11.7mm
Maximum Excursion (X peak) : 23.4mm
Mechanical Excursion (Peak-to-Peak) : 40mm
Mechanical Q (Qms) : 9.68
Sensitivity : 89 dB/W/M
Total Loudspeaker Q (Qts) : 0.66
Avaialble in the UK for around 64UKP plus P&P. Any comments anyone?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 4th January 2004, 07:34 PM   #22
Nuuk's Avatar
BTW T, I have just put that little EQ circuit into my OPA627 buffered IGC and it's magic! I haven't found the cause of the lack of gain in the VBIGC yet but whatever it is, it didn't allow the EQ to work properly!
Thanks again for that circuit!
Not only is the bass more prominent but the clarity of the whole lot seems better too. So what would it be like with extra woofers?.........
4 Pyle PPA 15 woofers (suitable for Open Baffle Bass) zobsky Swap Meet 1 17th December 2007 04:38 AM
16 Ohm dipole woofers on Ebay Magnetar Multi-Way 3 29th November 2007 03:32 PM
NHT woofers in dipole. al2002 Multi-Way 4 27th March 2006 03:41 PM
Would this sub be suitable for dipole or horn loading or both? eRiCdWoNg Multi-Way 6 31st July 2004 04:15 PM
Has anybody used the Peerless SLS woofers in a dipole? capslock Multi-Way 1 15th December 2003 11:42 AM
Page generated in 0.08212 seconds (67.22% PHP - 32.78% MySQL) with 10 queries
