Building a big two way system, a homage to the KEF BBC LS5/1A
Old 21st February 2014, 03:43 PM   #1
darkmatter is offline darkmatter  United Kingdom
darkmatter's Avatar
Question Building a big two way system, a homage to the KEF BBC LS5/1A
Always up for a challenge have recently been considering this proposition
Here is the original which used a Goodmans C129/15pr in the A version and two Celestion HF1300 tweeters.
For a clone one could use a pair of Audax TW034 X0 tweeters, but for the Bass? which 15" unit can operate up to 2K?
Old 21st February 2014, 03:44 PM   #2
darkmatter's Avatar
For the LS5/1 and LS5/1A the following information is given in the BBC document ENG INF No. 43, from which I quote:
"LS5/1, and LS5/1A
The studio versions of the LS3/1 and A, designed to replace the LSU/10. The cabinets were larger than the LS3/1 and the tweeters were mounted above the woofer, rather than in front of it.
The following units were used:
Plessey (LS5/1) or Goodmans C129/15pr (LS5/1A), 15-inch paper cone woofer
2 x Rola-Celestion HF1300 tweeters. "
KEF /BBC DESCRIPTION FOR LS 5/1AC:
BBC MONITOR SPEAKERS
The monitor loudspeaker used by the BBC to judge the quality of its radio and television programmes has been developed by a highly experienced team of research workers and studio operations engineers over many years. Infact the model in current use is the result of thirty years continuous experience in operational broadcasting in which period the best brains and ears in Britain have contributed to its evolution. The basic conception of the BBC Monitor loudspeaker is quite different from most domestic high fidelity speakers in that the latter are usually only intended to give pleasing reproduction of a diversity of available programme material. To this end reasonable variations in tonal balance and colouration are considered admissible or even desirable if they produce aesthetic pleasure and it is not generally possible to control these effects sufficiently to ensure consistent performance between samples.
On the other hand a monitor speaker must produce the programme signal with the greatest possible accuracy without modification of tonal quality and devoid of colouration. Broadcasting and recording organisations use high quality speakers to ***** the aesthetic and technical merits of their programmes and guide them in obtaining suitable microphone placing and studio conditions. It has been found by experienced engineers around the world that monitoring on mediocre loudspeakers can result in poorly balanced programmes due to faulty microphone technique as well as to allow technical faults to go unnoticed.
The BBC monitor Loudspeaker represents the best possible compromise between all the various requirements in the present state of the art added to which it has been tested at every stage of its development by subjective comparison between the reproduced sound and the original. In this regard this loudspeaker is virtually unique since no other organisation has access to such splendid facilities for both subjective assessment and technical analysis.
DESCRIPTION
The speaker system employs three units, which together cover the audio range available from present day records and broadcast programmes. The enclosure is constructed from high-grade veneered chipboard of a quality, which has been found by experiment to possess the smallest degree of self resonance of all suitable construction materials. The structure is reinforced by internal partitions which restrict the vibration of the back and sides and also by a metal strut between the front and the back panels. Mudocel damping is applied to the top panel.
The internal volume of the enclosure is 4.7 cubic feet and a small vent resonating with the volume of about 50c/s is used to give a slight boost to the low frequency output. Standing wave effects are damped by internal pads of absorbent material.
LF UNITS
The lowest frequency unit is a 15 inch paper cone type with a 3 inch diameter voice coil and PVC roll surround. Its axial frequency response extends smoothly up to about 2 Kc/s and it is relatively free of colouration effects. The sound output for this unit radiates through a vertical slot 7 and a half inches wide to ensure good horizontal dispersion up to the crossover point with the high frequency unit s at 1750 c/s.
HF UNITS
Two identical HF units are fitted each having a phenolic impregnated diaphragm. The frequency response extends smoothly up until 13kc/s above, which it dies away in a regular manner. Tests have shown that the output to be free from prominent low damped resonances. The two HF units are mounted in a vertical line above the LF unit in such a way that the separation between high and low frequency sound sources is not noticeable to listeners located over four feet away. Both units are operated in parallel at middle frequencies to increase power-handling capacity in the region close to the crossover point.
Above 3Kc/s the input to the upper HF unit is reduced to induce dispersion in the vertical plane and the phase is retarded as to direct the combined radiation pattern upwards
CROSSOVER NETWORK
A thirteen element printed circuit crossover network incorporates facilities for equalising minor irregularities in the LF unit as well as providing for adjustment for relative levels of LF and HF units in 1 DB steps. An additional network corrects the diffraction effect at low frequencies due to the finite size of the cabinet, as well as the low frequency loss due to the motional impedance.
ALTERNATIVE CABINETS
There are two versions, one a floor standing cabinet for studio and control room work and a suspended model for use in television control rooms.
The floor standing speaker model LS5/ 1A is intended to be operated on a 15 inch plinth above the floor which positions the HF unit at optimum listening height.
The plinth is designed to accommodate the equalised power amplifier conveniently beneath the speaker enclosure.
The suspended model is equipped with metal suspension gear, which enables the entire speaker to be tilted downwards at the required angle The LS5/2A requires additional equalisation at low frequencies to compensate for the loss of floor reflections. A suitable equaliser is available which can be incorporated with the power amplifier if required.
Both cabinets are available in a choice of oiled teak veneer or hammer grey lacquer.
SPECIFICATION
SIZE: LS5/1AC 33 X 19x 17 inches
Weight: 82 Lbs
Nominal Impedance 25 Ohms
Maximum input: 35 watts R.M.S
Frequency response : 40 –13 K/cs +_ 5db
Directivity index: Better than 54 db up to 3 Kc/s reaching 7db at 10 Kc/s
Calibration Accuracy: The axial frequency response checked against a BBC approved standard sample is adjusted so that the curve of the loudspeaker under test does not differ from that of the reference loudspeaker by more than the following amounts:
50 c/s - 200 c/s +_ 1.5 db
200 c/s – 400 c/s 0db
400 c/s – 13000 c/s +_ 1.5 db
13000 c/s- 15000 c/s +_ 2 db - infinity
The reproduction of the Loudspeaker under test is also compared with that from the reference speaker using high quality programme sources and white noise.
LF Unit: 15 inch Heavy paper cone with plasticised P.V.C. Roll surround.
Fundamental resonance: 25 c/s
Flux density: 9000 oersted on a 3 inch dia centre pole
Total Flux : 16000 maxwells
HF Unit: 1.5 inch diameter direct radiator with Phenotic impregnated - fabric diaphram
Flux density : 10,000 oersted
Total Flux : 25,500 maxwells
Crossover Network 13 Element printed circuit network employing Radiometal - - cored inductors and closed terminal metallised foil capacitors. - Completely enclosed and shielded in a steel case.
Input Connections : Canon XLR3 . Other connectors can be fitted to suit req.
Plinth: PLS5/ 1A Constricted from heavy plated steel finished in - - satin chrome with amplifier section brackets and heat shield.
Equalised Power Amplifier: Type MA40/LS5/1a . Fixed bias push pull amplifier delivering - 35 watts output over the entire audio range . The input
circuit is arranged for bridging 600 0hms balanced line at
- zero level and incorporates equalisation for the HF loss due - to roll off in the upper high frequency above 3 kc/s An input - attenuator is fitted giving infinitely variable control of - sensitivity. Output impedance of 25 ohms.
Input Connections P.O . Jack No. 500B6 in parallel with Painton 4 pin socket
Type 310035
Output Connection : Terminals
AC Mains Supply 110-140V or 220-250 V 50 c/s adjustable
Speaker units
LF unit : 15 inch (Unidentified)
HF Unit: Very powerful KEF T52. Same as fitted to the KEF KM1 studio monitors.
Old 21st February 2014, 03:47 PM   #3
darkmatter's Avatar
A 15" unit that might work?
SB Acoustics :: 15" SB42FHC75-6
... but a notch filter required at 1.6K right near x-over
Old 21st February 2014, 04:48 PM   #4
ticovski is offline ticovski  Europe
SB doesn't look smooth at all
Maybe this one, cheaper also, BD15;
Old 21st February 2014, 05:05 PM   #5
darkmatter's Avatar
Is this available in the UK?
Old 21st February 2014, 05:24 PM   #6
Netherlands, bd-design
Old 21st February 2014, 05:42 PM   #7
darkmatter's Avatar
Nice woofer but too sensitive and not enough bass extension for this project, does look like a very a good design though
Old 22nd February 2014, 04:11 AM   #8
Inductor is offline Inductor  Portugal
Inductor's Avatar
The Volt driver looks like it's very adequate. It's good for a BR speaker ~86L@34 Hz (as a starting point/alignment). 2π: 95.6 dB/2.83V/m, 94.6 dB/W/m; 4π: 91.6 dB/2.83V/m, 90.6 dB/W/m.
Volt RV3813 15" 500W 8 Ohm Radial Chassis Loudspeaker Driver 316.99
Volt Loudspeakers - R3813
It's going to be a difficult project if not using the same drivers. Why? Vintage looks vs. nostalgic vintage sound ??? Does it have anything you classify as good besides the design problems and intrinsic no-no's.
What tweeters are you looking at vintage or recent? Some links/ideas.
Seas T35C002 E0055-06 Tweeter - Excel Series
E0055-06 T35C002
Seas 27TFFNC/G H1396-04 Linkwitz LX521 tweeter
H1396-04 27TFFNC/G
SB Acoustics SB26STCN-C000-4 Tweeter, Free UK Delivery.
SB Acoustics :: SB26STCN-C000-4
Old 22nd February 2014, 09:47 AM   #10
darkmatter's Avatar
Many thanks Inductor for taking the time to research this plenty to go through
Building a big two way system, a homage to the KEF BBC LS5/1AHide this!Advertise here!
Need some major help building a system! BONGzzy Chip Amps 22 16th May 2014 05:44 PM
Building a 2.1 system. Any suggestions? cwteoh Chip Amps 22 12th December 2011 07:28 PM
Building my system and wondering... Erik Bult Solid State 1 27th September 2008 05:07 PM
Building a system systemerror909 Multi-Way 6 29th April 2005 09:12 AM
Need help in building a system deathmetal Car Audio 3 9th October 2003 01:56 AM
