Nao Note II RS: CNC cut baffles in UK.
I now have CNC cut side panels available.
6mm holes have been drilled on the inside of each panel for locating dowels to make assembly easier.
There are four holes for the bottom panel, two holes for the mid panel and two holes for the top brace.
A pivot hole for mounting the woofer frame has also been drilled.
A drill template is available for drilling into these panels.
All panel edges have been round over with a 4mm radius bit.
Price for the four panels to build a pair of speakers are £95.
P&P will be quoted on request as I get a lot of interest from abroad and prices vary considerably.
I am currently making a dowel jig to drill the bottom, middle and top brace which I am looking at including in the sale of the side panels for easier construction.
Will update this post when completed.
