Glueing 3.6mm plywood or veneering for best sound?
Old 14th February 2014, 12:20 PM   #1
Stewart Holmes is offline Stewart Holmes  United Kingdom
Default Glueing 3.6mm plywood or veneering for best sound?
Hello, am in the process of building my first 2-way speakers using seas drivers and plan on glueing 3.6mm plywood (then stain) instead of veneer to existing 18mm MDF and 4mm bitumen pads on inside of cabinet. My intent is to stop the box resonating but was wondering if it will make any audible difference. The cabinet dont vibrate too much and i do have braces. Thanks.
Old 14th February 2014, 03:27 PM   #2
Greebster is offline Greebster  United States
Greebster's Avatar
would be fine and improve things a bit as long as it is void free.
Old 14th February 2014, 03:48 PM   #3
Thanks again Greebster, glad it could improve things, makes it worth while, i was planning on using a contact adhesive or veneer glue, which would u choose?
Old 14th February 2014, 04:25 PM   #4
Greebster's Avatar
Elmers
Wouldn't use a contact cement do to void issue, others will argue this. A good glue like titebond would be my preference. Slow curing, easy water cleanup, but must be clamped prestigiously. Vacuum bagging also works well.
Old 14th February 2014, 04:56 PM   #5
Thanks again, i'll keep you posted on how i go on. Vacuum bagging sounds like a great idea
Glueing 3.6mm plywood or veneering for best sound?Hide this!Advertise here!
Glueing MDF enough? protos Multi-Way 23 24th April 2015 09:17 PM
which sounds more open a driver with Cms of 4mm/N or 1.6mm/N? rhythmsandy Multi-Way 1 23rd August 2013 04:37 PM
Wanted Alps 20k stereo pot. 6mm shaft. robgilmo Swap Meet 8 17th December 2012 04:25 PM
Plywood not glueing well amo Multi-Way 7 17th July 2004 02:27 AM
Source for thicker than 1.6mm PCB?? Magura Parts 2 25th May 2004 02:06 AM
