Enclosure for Crites CW1526C 15" woofer
Old 5th February 2014, 06:44 PM   #1
mitchba is offline mitchba  Canada
mitchba's Avatar
Default Enclosure for Crites CW1526C 15" woofer
Hi, I do not have any experience with programs such as WinISD Pro, but I am willing to learn.
I have a 3-way Bob Crites Cornscala Type C that I am happy with the sound quality. Some day I would like to add subs, but for now, I just want to learn more about calculating box volume based on these driver parameters that I got from Bob:
CW1526C cast frame. Replacement for the Klipsch K-33E used in Cornwall.
FS is 26.3, Re is 3.36, VAS is 506.3 Liters, BL is 12.49, QM is 9.93, QE is 0.27, QT is 0.26. Sensitivity is 97 db. Coil is 1 mH.
Pmax is 150 watts. Xmax is 7.15 mm, MMS is 75.5 grams, Cms is 0.486 mm/N
When looking at adding these parameters in WinISD Pro, I am confused that I have QE, but the program wants Qes, same goes for QT and QM.
Any assistance in pointing me in the right direction would be much appreciated.
Regards, Mitch
Old 5th February 2014, 09:26 PM   #2
PeteMcK is offline PeteMcK
QE = Qes etc...
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 5th February 2014, 10:41 PM   #3
mitchba's Avatar
Thanks. Tried that and got several errors in WinISD. Then it seems that WinISD, running in compatibility mode, complains of divide by 0 and access violation errors.
Any suggestions other than WinISD Pro?
Old 5th February 2014, 11:20 PM   #4
Try Unibox: UniBox - Unified Box Model for Loudspeaker Design - Kristian Ougaard
Old 6th February 2014, 03:10 AM   #5
mitchba's Avatar
Thanks! Works perfect. Cheers.
Old 17th April 2014, 02:10 PM   #6
_henry_ is offline _henry_  Australia
actually i just simulated the vented box for this for a guy in aussie based on your parameters , it works well for 165-195L
File Type: gif crites 15inch vented 192L Fb 31hz excursion.gif (9.2 KB, 145 views)
Enclosure for Crites CW1526C 15" wooferHide this!Advertise here!
4-sale Bob Crites 15" woofers CW1526... sklimek Swap Meet 3 27th April 2014 09:08 PM
Possible Crites Klipsch Woofer Sub For EV Sentry III peteleoni Multi-Way 1 31st October 2012 02:27 AM
Bob Crites 15" Cast Woofers zcables Swap Meet 10 22nd August 2012 11:25 PM
FS: Crites CW1526C 15 Cast Woofers- Cornscala or Klipsch Replacement tubesandhorns Swap Meet 1 2nd November 2011 10:12 PM
15" woofer in sealed enclosure KCCT82 Multi-Way 23 18th January 2008 03:45 PM
